Small Amp To Fit Behind Screen In Dash?
  • Small Amp To Fit Behind Screen In Dash?
    Hi,
    I have a golf MK6 & am looking for an amp to go behind my Lilliput screen in the dash. I have found the Xtronics amp with built in tuner which would be perfect, but it is quite expensive & they have only replied to one of my emails out of 4 in the last 6 weeks, so I dont feel comfortable with them for any support/come-backs. an anyone recommend anything else for me? It must be four channel & if it is in the UK then even better!
    Many Thanks
    Maybe he is busy
    i have used these guys before and have never had a problem they supplied me 20 of thesses units ea an i and s units
    you need to go to datalex support and attention your emails to LUC if you have any tech issues or if you wish you can all so contact myself i no these units very well and are happy to help you out
      this is a kit for self assembly;
      http://41hz.com/shop/item.asp?itemid=796&catid=
        http://www.bybyte.com/amp.htm
        EWF, HORM, MinLogon on XP.
        Zotac ION Atom N330, 2GB low-profile RAM, M3-ATX
        Win Embedded Std 2011 RC
        OCZ Vertex Turbo 30GB SSD
        Lilliput 629 Transflective, WRX Screen Mount
        BlueSoleil BT, i-Blue GM-2 GPS, DirectedHD Radio, Andrea Mic
        VoomPC 2
          I wonder if you could use an Alpine KTP-445. I know they are designed to plug into >2005 alpine headunits, but I have to think it would have power, input and output connections that you could rewire as needed. Probably contact Alpine and ask.
          http://www.amazon.com/Alpine-KTP-445...9347473&sr=8-1
          System always under construction
            1 or 2 of these for headunit like power
            http://www.parts-express.com/pe/show...number=300-385
            All you need is a 2 to 4 amp 12V regulated power supply. If your carpc power supply has enough extra on the 12V to supply one you are good to go.
              didn't see it mentioned, so i figured i'd add to the mayhem
              some members have used a 'motorcycle amp'(search ebay) in their installs, and have said that they have just as good of audio quality as a factory head unit, though i don't use one, so can't be sure...
              next project? subaru brz
              carpc undecided
                Thanks for all the replies! I have already looked at the motorcycle amps, but they are all 2 Channel & only 10!!! so figured they would be 10 Sound quality? I really just wanted something to plug into the existing wiring loom & then plug into my pc, but guess I am being too hopeful......
                  i have seen reports that they are just as good as the factory head unit in sound quality, so even at 10 pounds, they should be decent.
                  i have not seen any plug-and-play solutions to a carpc-amp for any cars, so i think you might need to lower your standards a little
                  if you enjoy a little soldering project, i have heard excellent things about the 41hz.com amps, and have been meaning to build one, just haven't gotten to it yet. they also offer pre-built units, but what is the fun in that?!?
                  carpc undecided
                    Just to update anyone interested, I installed a Mcfun 4Channel Car/Bike Amp for 24 & it is fed by a 15 GStar 5.1 usb Sound Card & the sound quality is superb. The only thing I have to do is mount a fan to the amp as it gets VERY hot!!
                      Mcfun 4Channel
                      How's this doing? Gone pop yet or thumbs up all round?
                      Can't see easy mounting option for second heatsink, but 11cm!!
