Home speakers in a car
  • Home speakers in a car
    This may seem a bit weird or "welfair" but idc i have 2 home stereo speakers in my house and i want them in my car but idk how many ohms they are. the speakers are from my parents aiwa cx-nmt520. If you can please let me know how many ohms the speakers are and what i would have to do to put them in. Thanks
    You will not get anyone on these forums who will recommend using home speakers in your vehicle.
    As far as the ohm rating of the speakers, that should be in a label or in the specifications of the speakers.
    How about the Wiki?
      Haha well these speakers ended up being amazing! Better then 6x9s and better quality. If you want home speakers in your car do it sounds amazing! No need to spend 100$ on 6x9s when I have home speakers that sound better
        Meh, there are high quality automotive speakers, and low quality home speakers. One is not inherently better than the other.
        The biggest problem you'll run into is most home speakers are 8 ohm, and most automotive amplifiers put out the most power at 4 or 2 ohms. So you'll only be getting half (or one quarter) the amount of power the amplifier is capable of putting out.
          power yes, but the clarity in a higher ohm setup is improved because the amp has a finer control over cone movements, and output freq... everything in audio is give and take...
          next project? subaru brz
          carpc undecided
