Audio specs advice needed, fuse/wire size, etc
  • Audio specs advice needed, fuse/wire size, etc
    Hey All. I'm hoping you can help me verify this setup will function ok, and on top of that be safe. I'm fairly certain the specs in the photo will be ok. The only piece I'm worried about is the Battery-to-Distribution block wire size.
    * Should I up the Battery-to-Distribution block wire size to 2gauge? I'd prefer to stick with 4ga if i can. 2ga is a PITA to work with.
    * Are the additional 40amp fuses at each Amplifier and 15amp fuse at the PC overkill?
    * Is this setup correctly?
    TIA!! :cheers:
    Head Unit: Custom Carputer + Touchscreen
    Front Speakers: Polk DB6501 component
    Rear Speakers: Polk DB651 coaxial
    Sub: Kicker CVR 12"
    Amp 1: Audiobahn A4002T mono
    Amp 2: Kicker ZX350.4 four channel
    Also, if you're interested, my PC specs are as follows:
    LCD: Lilliput 7"
    Case: Morex 3688
    Mainboard: MSI MS-7265
    Memory: Transcend 2 x 1gb DDR2 667
    PSU: M2-ATX
    WiFi: Qcom LR802UKN wireless N
    DVD: Panasonic CW-8124-B DVDrom
    HDD: Seagate 2.5" 80gb 7200rpm Extreme Environments drive
    CPU: Intel T2500 Core Duo 2.0GHz
    Software: Windows Embedded Standard, Road Runner front end
    Hi i think you need to locate one 100A fuse as close to the battery as possible.
    Then the pair of 40A and the 15A at the distribution block is good .
    Dont forget to also add a fuse for the display at the block.(unless fused inside computer)
    To figure the gauge needed correctly i need to know four things.
    #1 The power used by amps,computer and display
    #2The distances from battery to the buss .
    #3Then distance from the buss to both the amps and computer.
    #4Finally the length of the ground cables .
    I then enter the above info into the table for dc voltage drop .
    The wire guage that will give less than 5% drop is correct for this application.
      i would really consider running 1/0 ga to the distro block-- sure it is a pain, and a little overkill, but would be worth it later if you end up upgrading amps (i ran 8 ga to my carputer ) i prefer to fuse-down any setup then to have to pull out everything for every single upgrade i make-- so it kind of depends on how permanent your setups are... my entire car is a hobby-- i don't think i have ever gone an entire year without changing/modifying something on any of my previous cars
      next project? subaru brz
      carpc undecided
        yeah, i suppose that makes sense. If I go with bigger wire everywhere I'll be future-proofed against potential upgrades. Especially from the battery, that's the hardest one to re-run.
        What do you mean by "fuse-down"?
          also: 8ga to the PC?? yikes lol. that's plenty
          the automotive PSU's come with all 16ga wire. Most traditional ATX psu's use 18ga.
            well, i use a dsatx, but had a some of 8 ga laying around from my last car-- it was too short to use in this car, but long enough for the carputer, so in it went... and i really wasn't crazy about running 12ga to a device that broadly claimed "220 watts"...
            by fuse down, i mean fuse for the load, not the wire-- ie: if you connect a lightbulb that draws 1 amp to a 0ga wire, connect a 1amp fuse..
            carpc undecided
              oh oh, right. Yeah i added up the total amp's of fuses on the devices and got 95amps. So i was going to put a 100amp fuse on the main line at the battery.
