bmw eco mode
  • bmw eco mode
    ok guys i have fitted a kvt-924dvd to a 09 plate bmw, it has eco mode,
    when i apply the clutch and put it in gear the engine starts back up but the stereo and all auxcillarys reset any ideas?
    could be the ignition switched and permanant live wires connected the wrong way around, the wiring harness behind your dvd unit will probably have a red and a yellow wire with a bullet connector in the middle, because these can be different ways around in the standard ISO connector found in most cars. check with a meter or test lamp to see if the ignition switched positive stays on when the problem occurs, pretty sure it will be these two wires that are the wrong way round.
    Progress: ~99%
    Fitted, Running.
    boot install to tidy when better weather arrives
      the wires are the worrect order as its holding memory...
