2, 2ohm Dual Voice coil subs to mono amp
  • 2, 2ohm Dual Voice coil subs to mono amp
    ok, Here it goes,
    I have 2, 2ohm dual voice coil Kicker CVR 12" subs in a box that will be placed under my truck seat (down fire). The subs are 800 watt max, 400 watt rms. My head unit has a SUB jack that is mono. To my best knowledge, i need a mono block sub amp. I have wired the subs in parallel (as the kicker book said) and wired to the jacks that are mounted in the sub box. Ultimately i now have only ONE set of wires (one positive and one neg.) to run to the amp. All the mono amps i have looked at have TWO places to put two sets of wires. What am i missing?. Any help would be greatly appreciated
    Thanks in advance
    Hey and welcome to the website! This website is dedicated to the process and technologies involved with putting a computer in a car for music/gps/etc, and this sub forum for the issues integrating with a car audio system. While someone here may have an answer for you I would hate for you to wait around on a forum that isn't really for you. You would be better off asking that question on a car audio dedicated forum.
    RevFE
    My Shop
      i may have an answer
      most monoblock amps with multiple output terminals are really just have multiple parallel outputs-- so connecting 2 subs to the outputs on the amp is the same as what you did inside the box..
      now you just need to make sure that the amp can support the load you have setup. because, if you paralleled both vc's, and then paralleled the subs, you are at about a 0.5ohm end load on the amp-- and that will be relatively hard to find a amp for.
      imo, you should wire them for either a 2, or 4 ohm end load, so that the proper amp will not cook..
      next project? subaru brz
      carpc undecided
        Well, i have wired the voice coils parallel and the subs in series(as the diagram shows on the Kicker website). which gives the end load 2ohm. but... the diagram also shows voice coils in series and the subs in parallel which still gives a 2ohm load. Is either way any better or just personal preference?
          not really. just different options-- that is the entire reasoning for dvc subs-- more wiring flexibility.
          carpc undecided
            Thank you soundman. you have helped me more than you know. now i have a stupid question. i have one set of wires coming from the sub box now because i have wired the subs together. That one set of wires hooks to the amp, but the amp has 4 screws: left + right+ and left- right-. which set of screws do i hokk the one set of wires to? and the amp only has one channel mono. i am actually losing sleep over this..haha
              are you sure it is a mono amp? what is the model #?
              because the blocks are usually tied together, you should be able to just connect it to the same parts-- ie: either left +/-, or right +/-..
              carpc undecided
                Kenwood KAC-9105D 1800 watt
                  These diagrams should help you figure out how to wire your box to the amp correctly.....
                  http://www.klausaudio.com/subwoofer-...ng-diagram.php
                  Hope this helps!!!
                  Linux(Learning the curve...Like when driving!!!)
                  Worklog!!!http://www.mp3car.com/vbulletin/fabr...l-worklog.html
                    This is a two channel amp. You need to wire your subs like this with that amp......
                    http://a248.e.akamai.net/pix.crutchf..._2-ohm_2ch.jpg
                    If you wanted to be pushing 2ohms, you should have gotten 4ohms DVC's instead and wired like this...
                    http://a248.e.akamai.net/pix.crutchf..._4-ohm_2ch.jpg
                    What you need for you current configuration is a mono amp wired like this....
                    http://a248.e.akamai.net/pix.crutchf...2-ohm_mono.jpg
                    Hope this solves your problem!!!
                      the 9105 is a mono amp. the 2nd number on kenwoods amp model #s indicates the number of channels. so wire it how you initially had it and just choose one of the sets of terminals to hook your subs to.
                        Originally posted by YESindeed View Post
                        the 9105 is a mono amp. the 2nd number on Kenwoods amp model #s indicates the number of channels. so wire it how you initially had it and just choose one of the sets of terminals to hook your subs to.
                        You can wire it using one side...But it is a "TWO" channel "MONO" amp. Trust me on that! Been installing car audio since high school!!! A true mono amp only has one channel to connect to, and most are capable of doing a 1ohm load. Should you decide to bridge this amp, you will be getting a 1ohms load on it...which may fry it(been there...done that)!
                          it is technically a 1 channel amp with multiple outputs:http://www.kenwoodusa.com/Car_Entert...iers/KAC-9105D
                          and those diagrams you linked to also show a similar monoblock amp setup-- multiple +, and - outputs but still mono...(otherwise, could you describe how they are different?)
                          for connecting 2-2ohm dvc subs as a 2 ohm load, simply series parallel the vc's-- series the vc's of each sub, then parallel the 2 subs together-- and you will have a 2 ohm load...
                          a 4 ohm load is impossible to use all 4 vc's with, but if you only use one vc of each, and series them, it will be a 4ohm load...
                          carpc undecided
                            What he said...
                              so basically i will be connecting to only one set of the output connections, one pos. and one neg. leaving the other set with nothing connected to them. right? maybe when the amp gets here, i can read the directions.lol
