Deck now causing terrible buzzing noise after 2 years...
  • Deck now causing terrible buzzing noise after 2 years...
    Have an Infinity 4-Channel Amp powering a set of Alpine Type R Coaxials (front) and Alpine Type S Coaxials (back) as well as a Infinity Mono powering two 12" Infinity subs. 98 Firebird Formula. Pioneer Deck. Would have to check model for sure.
    Thus far I've had no real problems with the system (built it and installed it roughly 2 years ago). A few days ago I had a very bad buzzing noise coming from the speakers and even a worse alternator whine. I thought it was the amps but plugged in an mp3 player directly to them and had no problems. Thought it was the signal wire but pulled out the deck and ran new rca's across the car to the amps and still had the same problem. So I've managed to figure out its the deck. I jiggled around and quickly brushed over the wires to make sure there wasn't a bad connection especially with the ground but didn't see anything wrong.
    Haven't seen anything especially weird about the deck. The noise comes from no matter what source and does not change with volume on the deck. When I move from sound level 1 to 0 it makes a loud popping noise and vice versa.
    PS: My alternator also went out the same day all this jazz started happening, I've since replaced it and had no issues alternator-wise. Could I have messed something up with the ground wire down there? Surely not?
    Suggestions welcomed!
    when the alternator failed it could have caused a spike in your power system and your HU might have been damaged in some way, my Panasonic HU did the same thing, loud pop when turned all the way down and alternator noise, i replaced it and no problem, my HU was several years old anyway. does the noise come out all channels or just the sub?
    MY INSTAllS:
    http://www.mp3car.com/vbulletin/show...e-install.html
    http://www.mp3car.com/vbulletin/show...tallation.html
      Does the noise occur with the car off?
      My Nearly Complete Car:
      http://www.mp3car.com/vbulletin/show...ed-car-pc.html
      Micro Control Center... Control Your Car Across the Internet
      http://www.mp3car.com/fusion-brain/1...-internet.html
      Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
      http://paulfurtado.com/
        Dont some headunits have a tiny fuse on the connection to ground on the rcas? some sort of miniature fuse on the pcb to somehow protect it, if the ground to your amp came disconnected it may have grounded down the rca lead and blown this, i saw something about basically bodging a ground wire onto the sockets, will see if i can find it, might be an easy one for a quick test
        Progress: ~99%
        Fitted, Running.
        boot install to tidy when better weather arrives
          have a look at this, maybe its possible this might work.
          http://bcae1.com/images/rca/temporar...eldrepair.html
          Progress: ~99%
          Fitted, Running.
