What is causing this noise from my sub? (Clip included)
  • What is causing this noise from my sub? (Clip included)
    I have a strange noise that comes out of my sub but it's not all the time.. It's also not every day.. I had thought it may be my phone but if that was the case I would think it would be more consistent as I always have my phone with me and it's always syncing..
    Anyone have any ideas what could be causing this?
    http://www.youtube.com/v/Q0apEdRC6-0
    Current Vehicle: 2007 Dodge Nitro
    Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
    First Vehicle: 2003 Ford Ranger
    Throw in a different sub and see if it still occurs.
      Could that be it? I don't have another sub to try...
        It almost sounds like the noise a ported sub makes when the port is sized too small.
          No I don't think it's anything with the port. It's definately a sound from the sub. Almost like Morris code.
            sounds like feedback from microphone. have you muted line in and mic just to see? just my 2 cents SNO
              What kind of cross over and amp are you using. It is a higher pitch sound than a cross over should allow to even get to the sub, so it is either on the output of the crossover or the amplifier, or interference in the power supply cabling to either. Do you have another amp you can try with the sub and crossover. If it is still there, then it would be the crossover. If it is not then it would be your amp.
              CAR: 2007 G35 Sport Coupe 5AT
              HARDWARE: Dell D630 w/ dock, internal 80G HD, internal 320G HD, Verizon Wireless Card, iBlue GM-2 GPS w/iGuidance, OBDPros w/DashCommand, Visteon HD Radio w/ Home Made Cable, Current Version of RR w/ DFX Skin. My Install.
                Thats what it sounds like to me too...... Lie the mic is too close to a speaker and causing feedback. Have you checked to see if you mic input is muted or not?
                1X Ainol Novo Flame Tab
                4X MK808b
                3x Perixx Touchpads
                3x 7 inch Screens
                1X 7 inch motorized Screen
                1x Win 7 PC
                  FYI - that voltmeter fluctuates a lot, and gets over 14.4V etc.
                  What is it monitoring?
                  If it's ignition or dash, make sure your ground connections (chassis-engine-battery-) are properly connected and sized - especially if the alternator is sensing battery voltage!
                    Does it make a "pop" when you turn the volume all the way to zero or turn off the HU? It almost sounds like your HD is causing the interference, the frequency is pretty high, do you have the amp set to full, highpass or lowpass, you might be able to eliminate that sound with your amp if you set it to lowpass and adjust the frequency to 50hz or lower
                    MY INSTAllS:
                    http://www.mp3car.com/vbulletin/show...e-install.html
                    http://www.mp3car.com/vbulletin/show...tallation.html
                      Huh?
                        Sorry - it is an AFM. It looked like a typical bling voltmeter....
                          ? i re-watched the video a couple of times-- it is a black screen with the noise he is referring to-- i don't see anything..
                          i agree on the other points, it sounds almost like either a ground loop, or incorrect crossover setting..
                          next project? subaru brz
                          carpc undecided
                            I don't have a mic hooked up and even with all levels muted it still happens.
                            The AMP is a Kicker zx350.2. I don't have any separate crossover.
                              ok, what are the crossover settings set to on the amp?
                              carpc undecided
