BoomzBox HD
This topic is closed.
  • BoomzBox HD
    I purchased the BoomzBox HD a month or so ago. I installed it according to instructions but there is absolutely no audio. It finds stations without a problem. Anyone else have a problem like this or know of a solution?
    IPTV Shows
    what are u using it with?
    also what OS
    i assume the supplied software
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
      TinyXP. I've also tried it with XP Pro and Windows 7 Pro. I've tried the software that comes with it along with the RideRunner, Shotgun!, and DriveLine frontends. None of them work.
      IPTV Shows
        stick with the boomzbox software for now
        lets pick an OS here...
        i assume you read the manual
        the device is a composit device... 3 parts (4 if you count the hub)
        does the audio device should up, in device manager, and in Xp's sounds control panel
        or windows7 recording device (note it may be disabled)
        USB Audio Codec
        -Thanks
        Mitch
        www.rush2112.net
        Wind, Carry me home
          Everything shows correctly according to the manual. It is detected by the system and the COM port is active when the software runs.
          I will try re-installing everything when I get the vehicle back from the shop. Had an electrical short in the steering column.
          IPTV Shows
            you didnt answer my direct question
            ill ask again, does the audio device show up?
            and lets pick an os to get this working on
            -Thanks
            Mitch
            www.rush2112.net
            Wind, Carry me home
              Yes the audio device shows up. Yes it's enabled. I'd like to get it working on XP.
              IPTV Shows
                ok, lets do xp
                start boomzbox HD software.... after it finds tuner and is tuned...
                right click settings...
                and look at the audio settings, i show you mine
                then when you close the settings window, you should see dancing bars... as shown..
                if no audio, still, then its a tuner or interface issue(very rare)
                Mitch
                -Thanks
                Mitch
                www.rush2112.net
                Wind, Carry me home
                  It's working now. I removed and reinstalled the drivers and now it's fine. Must've been a corrupted driver. Sorry to bother you with the problem.
                  IPTV Shows
