Wiring Two Sundown SA-10s to Mono Amp
  • Wiring Two Sundown SA-10s to Mono Amp
    Hi, I'm looking into buying two Sundown Audio SA-10s to wire into my alpine PDX-1.600 Mono Amplifier. I was wondering whether to buy the sub-woofers with the Dual 4 ohm coils or the Dual 2 ohm coils. Also I wasn't quite sure how to do the wiring.. (Although I'm pretty sure I would run the subs in parallel)
    The sub-woofer enclosure I have that I received from my cousin has wire running from the outside into one of the boxes, and then a wire between the first and second box.. Is this okay or do i need to run the wire from the second box outside of the box as well? (If this isn't clear enough I apologize and can provide pictures.)
    Here are links to both the amplifier and Subwoofers:
    SA-10's: http://www.soundsolutionsaudio.com/s...Subwoofer.html
    Alpine Amp: http://www.crutchfield.com/S-564mDOv...DynamicContent
    Thanks for any help,
    Pete
