Which Soundcard for this setup?
  • Which Soundcard for this setup?
    Hello,
    I have browsed and searched other threads and viewed the FAQ but am still not quite satisfied.
    I have two amps and need to know what sound-card I should be looking for.
    I don't have any rear speakers in my car.
    I have a sub with a built in amp.
    I have an amp powering my front speaker.
    Therefore I need RCA from the PC to the sub.
    Therefore I need RCA from the PC to the amp which powers my front speakers.
    What sort or outputs / specifications should I be looking for?
    Thanks,
    Jack.
    Any 5.1 sound card should do. Then use 3.5mm to RCA to connect to your amps. That's what I did. Hope this helps!
    http://www.newegg.com/Product/Produc...-006-_-Product
      Okay so would this soundcard be suitable?
      http://www.ebuyer.com/product/246650
      And which outlet would go to general speakers and which to sub?
      Just want to be sure! =]
      Thanks,
      Jack.
        The documentation would tell you which jack is for which connection. Sometimes the jacks are configurable but you'll need to check unless someone else chimes in on this specific card and knows for sure.
        The specs do say 3 output jacks including a front & sub so you should be good to go!
          Ok thanks for your help everyone!
          Thanks again,
          Jack.
            jack this is not a problem, you must use a 5.1 sound card of any company and solve your problem as quick as possible.
            hope u might be understand what i told u.
