Directed HD Connect Car Radio
  • Directed HD Connect Car Radio
    is the Directed HD Connect Car Radio what i need to get am and fm into my carputer?
    thats what i use
      is there any where i can get the manual for it? how are you powering it?
        Manual: http://a248.e.akamai.net/pix.crutchf...7/60744000.PDF
        And as for the power - it comes with a cable that connects to your 12V, IGN, and GND wires.
        1999 Mercury Grand Marquis GS with: ASRock E350M1 w/4GB RAM, 80GB Intel SSD, Opus DCX3.120, Visteon HD Radio + HDR-USB, PL-18N wifi, OBDLink Scan Tool, BTA6210 BT, BU-353, Win 7 Ultimate, CF 4.0, Alpine MRP-F240 + MRP-T220, RF Punch 1572s, Kicker 8" Comp.
          i just have it wired to 12v and gnd, triggered by the psu trigger relay. i have no manual and it is really easy to work, just hooked the yellow to 12v, the black to gnd and the red to my trigger, plug in the antenna and serial cable and your off. oh, also the audio.
            if your using for carpc, it need to be on when the pc is on, so wiring RED to ignition is NOT a good choice
            since if your pc is going into standby when you turn off the key, it will still need to talk to tuner till its done the standby process
            -Thanks
            Mitch
            www.rush2112.net
            Sun, Come shine my way
            Wind, Carry me home
            The piece of me that died
            Will return To live again
