How can i install dual amps to the Telematics Bundle?????
  • How can i install dual amps to the Telematics Bundle?????
    HELP!! One for sub and one for speakers??
    If you're not going to add a crossover (which you REALLY should, not only for sound quality but for the longevity of your speakers), you can use something like these: http://www.amazon.com/Male-Female-Pi.../dp/B000I94FAE
    "Have we grown so hard we can't feel right or wrong, or have we grown so cold we just don't care?" - Dave Matney
    I don't currently have a CarPC, I just ask a lot of questions.
      Just maybe not those *exact* units based on the feedback they received *lol*
        Oh, very true. I just grabbed the first link that came up. Though, at $1.31 for the cheapest new ones, you might even go with them on the off chance they work just fine.
          *lol* Color me once bitten, twice shy
            ok ya ill need RCAs but how will i connect that to the motherboard one amp is my subwoofer and the other is for my speakers so im sure they need to be coinnected separatley to control them.... also is there like a program that u could install to control treble and bass and such?
              what do you mean by dual amps?
              you mean you want to install a really small amp in the case like a class-t tripath-chip amp?
              no, you can't. it won't fit..
              but if you want to connect to standard car audio amps, then yes, you can, you just need some 3.5mm-to-rca adapters.
              next project? subaru brz
              carpc undecided
                If you're talking about this bundle, you can't. Not without additional hardware, anyway.
                The EASIEST (and, IMO, the best) way to do it is going to be to get an external crossover, run a 3.5mm -> RCA adapter from the green output of the motherboard and dial in the crossover points manually. Depending on the crossover, you could run a single source and provide different crossover points for front tweets, front and rear mids, front and rear mid bass, and sub bass, all from the single input.
                After that, it gets a bit more complicated... you can get a USB Sound Card that supports 2.1 (or 5.1, but it makes things a bit more complicated) and hope it dials in the crossover point for you. Or go that route with any variety of 3rd-party software EQ.
                Or perhaps go the absolute most difficult route and install a version linux and hope someone's already done the driver-hacking for your mobo, and if they haven't, learn all the hardware and software programming required.
