Little help remembering winamp plugin name and how to permanently re-task a jack
  • Little help remembering winamp plugin name and how to permanently re-task a jack
    I re-installed recently with a new setup, and of course forgot how I got certain pieces of it to work to my satisfaction. So, if anyone can help out, that'd be great:
    1. Realtek HD audio, I have it set as 4 speakers (quadraphonic), but the blue line defaults after restarting to "line in". I know there's some way to retask this permanently, but damn if I can recall how, or find it in a search.
    2. Winamp plugin that will truly output stereo music to the rear channels. I had that as well before, I know I posted about it, but damned if I can find the blasted thing. Think it was a DSP one.
    2008 Ford Mustang GT/CS CARPC(99%)
    Software: Ride/Road-Runner, Digital FX skin 5.x, iGuidance 2011, GPSgate on Win7 64bit
    1. Permanently re-tasking the line in jack for Realtek HD chip on my motherboard(blue) to left and right rear:
    I did some major digging, exported the suspects from the registry before and after changing, compared using notepad++ and got my solution. Dirty, but functional.
    Realtek can suck me. They changed it up from before in newer drivers, as not only does it not keep the re-tasking, it defaults everything upon restart via other parallel registry entries. So just finding the pin number and setting the correct entry no longer does it as it used to (see here for more info).
    Anyhow I will post the registry file I am now loading via HKLM/software/microsoft/windows/currentversion/run via a new string entry doing "regedit /s filenameandpath.reg" in a bit for those interested. That solves it now without me having to sit and wait and press tiny buttons to re-task again on each boot-up.
    Here it is:
    Code:
    Windows Registry Editor Version 5.00
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E96C-E325-11CE-BFC1-08002BE10318}\0006\Settings\Drv6392_DevType_0662_SS174b437b]
    "Pin05"=hex:05,00,00,00
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\MMDevices\Audio\Capture\{0012cbc0-c458-4924-826f-e8a3bd2af7d9}\Properties]
    "{24dbb0fc-9311-4b3d-9cf0-18ff155639d4},3"=hex:0b,00,11,fc,01,00,00,00,00,00,\
      00,00
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\MMDevices\Audio\Capture\{2c405181-6d70-44a9-8e4f-b92c3587f5ed}\Properties]
      00,00
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\MMDevices\Audio\Capture\{3df8f789-828d-441b-a3c3-e2e46ae3d67e}\Properties]
      00,00
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\MMDevices\Audio\Capture\{4026589a-00a1-470f-8303-28fcbc49d41e}\Properties]
      00,00
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\MMDevices\Audio\Capture\{5f0b1bc3-a080-4df7-a028-071dea1d62b6}\Properties]
      00,00
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\MMDevices\Audio\Capture\{6a93d56c-aa2c-46d0-87f0-1f65c5654870}\Properties]
      00,00
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\MMDevices\Audio\Capture\{76331abd-d76b-41ad-aeee-ab2b621649a6}\Properties]
      00,00
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\MMDevices\Audio\Capture\{90023966-4143-424d-9d3a-230cb8e8aca8}\Properties]
      00,00
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\MMDevices\Audio\Capture\{a0c166c1-2828-4ec6-8198-3763b4dea428}]
    "DeviceState"=dword:00000004
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\MMDevices\Audio\Capture\{dfa283f8-f187-45c5-bf52-2c28f345f10d}\Properties]
      00,00
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\MMDevices\Audio\Render\{b23f2aa8-ece9-40c3-8cbd-fce19c8470d6}\Properties]
    "{9D631510-92A8-4a79-A79E-A83812C9C119},5"=hex:fe,ff,02,00,80,bb,00,00,00,dc,\
      05,00,08,00,20,00,16,00,20,00,03,00,00,00,03,00,00,00,00,00,10,00,80,00,00,\
      aa,00,38,9b,71
    Before, it was only necessary to do that first entry. Which changes places with the driver release number, note that in the registry naming path. Likely this can be trimmed down further, but I just slapped anything that changed in there after a retask. Unless you're running the exact same motherboard, windows 7 64bit, and realtek driver release use the above as only a guideline; as that will likely not be exactly the same for you.
    2. Winamp plugin to output stereo to 4 speakers or more.
    found it after much more research. The VL sound plugin for Vista is needed.
    The old "kb 5.1 surround" one won't work for any windows OS after XP (different mixing method is used for Vista and above, so that one craps out).
      Nice! This is exactly what I was looking for.
