Looking for an Amp
  • Looking for an Amp
    Hey, I'm new to these forums =)
    I'm starting to build my first sub/amp/box system. I'm planning on getting 2 SA-10 D4's and am looking for an AMP that could power these bad boys. The problem is I'm trying to stay around $250-300 or lower if possible. If someone could point me in some direction on an amp, or even what to look for, that'd be awesome.
    Thanks!
    Specs for SA-10s: (I'm getting 2)
    Features:
    Sundown Audio SA-10 10" Subwoofer
    Dual 4 Ohm Voice Coils
    Tinsel Leads Secured to Spider
    Strong Adhesives and Materials
    600 Watt RMS Power Handling
    Specifications:
    FS : 31.6 Hz
    Qts : 0.45
    Qes : 0.49
    Qms : 5.64
    VAS : 21.9 L
    Mms : 187.4 g
    Mounting depth = 6"
    Cut out: 9 3/16"
    OD with gasket: 10 3/8"
    XMAX: 19mm one way
    To get an amp that can push about 1200w RMS for under 300 is a bit unlikely. You may have to go with a not so much namebrand such as this amp here. It's a dual channel amp that's rated at 400w RMS on each channel. I know Pyle isn't the best of all brands and usually over rate their power output on their amps but their Dryver series are supposed to be pretty accurate from what I hear. Wire each sub as 2ohms and you should be good to go.
    Originally posted by Lincolnman
    Your English is fine, don't apologize. You're doing better than most Americans.
      or plan to run the subs with about 200-300w rms. anything over that is going to be much pricy-er then $300...
      next project? subaru brz
      carpc undecided
