CarPC to Factory Bose Amp
  • CarPC to Factory Bose Amp
    Is it okay to wire from a 3.5mm output on a PC directly to the inputs of a factory Bose amp in a 2003 G35? Does the amp want high or low level inputs? Does the PC provide high or low level inputs?
    Thanks!
    2003 G35; Factory Navigation; CarPC
    Progress [IIIIIIIIIIIIIIIIIII-] 90%
    PC provides very low level inputs (On the scale of 0-0.5 or 1volt). Generally lower than most amps are rated for. I can't speak for Factory amps, but most amps you buy in the store have low level inputs as high as 8v in some cases. You need to find out, perhaps from a G35 forum or look up the actual part number of the amp, what kind of inputs the amp takes.
    I would assume it is expecting low level inputs, but factory installed amps can be all sorts of weird things.
    RevFE
    My Shop
      I just did a head unit install on a mid 90's Camaro with the factory Bose system and I did have to use as line level convertor to lower the input level so chances are, yours needs a low level input.
        Yes, you will need something to go from the CarPC to the Bose amp. Let me dig through my pile of supplies from the various installs I have done on my 05 G, and I might have something that will help.
        2005 Infiniti G35 6MT Coupe Black/Black
        Core Duo CarPC
        CarDomain page
          Cool, thanks guys. I did just order a PAC-LD10. Right now the audio is fairly clear but is flat as you could imagine. Bass is non-existent. I hope this helps. I may have to rip out the rest of the Bose stuff at some point anyway, we'll see!
            I know im a few months late to the post. I also am looking to do a build and the furthest i got was how to get pc sound to the stock amp.
            Now I have found this device.(ROEM-NIS2).
            It allows aftermarket head units to adapt and be plug and play into the bose system.
            Now the question is based upon the allowed inputs What would it take from a pc audio device output (soundcard or interface) stand point to give me PC outputs that can be splice/merge into the aftermarket harness inputs
            LEFT FRONT LOW LEVEL (+)
            LEFT FRONT HIGH LEVEL (+)
            RIGHT FRONT LOW LEVEL (+)
            RIGHT FRONT HIGH LEVEL (+)
            LEFT REAR LOW LEVEL (+)
            LEFT REAR HIGH LEVEL (+)
            RIGHT REAR LOW LEVEL (+)
            RIGHT REAR HIGH LEVEL (+)
            LEFT FRONT (-)
            RIGHT FRONT (-)
            LEFT REAR (-)
            RIGHT REAR (-)
            or what hardware be required to give me these sorts of outputs from a pc
              Splice the stereo output from the PC and attach it to both the left and right low level inputs, that should do it! FYI I had to use the PAC LD-10 in order to get decent levels.
