suitable amps in a small area to work with?
  • suitable amps in a small area to work with?
    Finally started doing some of my new build, opting to skip the subwoofers until I stop blowing my fun budget...
    However, I got to thinking I might as well just order them, wire everything at once, and be done with that part of the build. Ok, so I will be ordering some of the 2" shallow mount, 13" power acoustik subs. However, with the box I am building, I realized I have no room for an additional amp for the subs .
    I'm currently running 2 cheap small 500 watt amps for the factory speakers. I'm thinking I should ditch these and look at an amp that can run my factory speakers and the subwoofers. 4 channel right? Or, are these 5 channel? I'm accustomed to home theatre stuff more so I'm not sure the terminology, aplogies.
    Anyways, I've been searching for a while for the smallest amps I can find. Found a mono one that fits my dimensions, but I'm not looking for mono here: Dimensions of my area are about 6.5" width, 3" height, 8" length. Also, not trying to spend alot, as I wasn't planning on this phase yet . Any help, pointers, recommendations would be appreciated.
    Current Worklog: TBA - '05 Rav4 (Mobo Dead). - Forums for Rav4 owners - Cooking website/forums
    -Basic forums live atm, come contribute!
    I assume you are running 4 speakers plus planning a sub? How many watts and what type of resistance do you need?
    Unfortunately I think you are going to have a really if not impossible time finding a 5 channel amp to fit in that area.
      Yes, 4 speakers and a sub. Here are the specs from the page (I don't know the difference in wiring for ohms):
      13" Single 4 Ohm Shallow-Mount Subwoofer
      Power Handling:
      Peak: 700 watts
      RMS: 350 watts
      I spent a lot of time searching around today but can't find much at all, so I think you might be right that it could well be impossible. I guess Ill just have to keep use one of older mono spares in the meantime. It's not gonna look right at first sitting out, but I guess I'll get used to it. Too bad I won't have any pictures of it until I'm done, so we'll see.
      I'll keep a lookout for an amp, or combination of amps, or something that might be do-able in that area.
        Yeah smallest 5 channel I have used/seen is a Apline PDX-5. I actually have one running my midbass and subs. But even it is too big and seems people are asking crazy $ for it now.
        openMobile - Download
        Like what you see? Donations are always welcome
          Well there is this amp that can fit inside of your space with the mono amp you mentioned.
          Click image for larger version
          It is rated for 30watts RMS @ 4ohms x 4 channels. This would be a good addition to the other amp.
          I see a downside to the other amp though. The sub is rated for 350 watts RMS with a 4ohm SVC. The amp can only handle only 75 watts at 4ohms. That isn't very much power for the sub. I'll have a look around and see if can't find anything for you. I'll let you know if I do.
          Originally posted by Lincolnman
          Your English is fine, don't apologize. You're doing better than most Americans.
