starting ipad install in f150
  • starting ipad install in f150
    i will be installing the ipad into my dash in place of my head unit. i will be using a clarion http://www.clarion.com/us/en/product...294767387.html DVC920 as a controller and the http://www.clarion.com/us/en/product...912142973.html DVH940 as the processor. I think I will have to wire an amp to the component speakers in the doors. I use an Audiobahn AA2002T http://www.sonicelectronix.com/item_...hn-A2002T.html as a sub amp for 2 10" Kicker C10's. I actually have another A2002T I would like to use for the R/L door speakers, but I am needing to know if this is possible and how to connect them.
    lets word this differently. Can a 2 channel. 2x50 watt amp run 4 JLaudio 6x9's
      It sure can as long as your 6x9's are 4ohms. This amp requires 4 ohms on each channel to get 50watts.
      Originally posted by Lincolnman
      Your English is fine, don't apologize. You're doing better than most Americans.
        For some reason i don't think it's that simple. Depending on how you wire the speakers, the amp is going to see either 2 ohms or 8 ohms (i think).
        OLD SYSTEM (DEAD)
        Intel D945GCLF2 Dual Core ATOM
        Lilliput 7" 629GL 2008 LED Backlight
        BU-353 USB GPS Receiver / iGuidance / IGO8
        M2-ATX Power Supply
        RideRunner Front End / Various Skins
        Windows XP SP3
          Your right. I had over read the 4 6x9s. I hadn't caught the 4 part of it so I automatically assumed it was 2. Anyways, if you have 4 of them then they will need to be either 2ohm or 8ohm. If they are 2 ohm then wire them as 2 pairs with each pair in series. But I highly doubt that's what they are. If they are 8ohm then wire them as 2 pairs with each pair in parallel.
