Carputer audio wiring advice
  • Carputer audio wiring advice
    Hi,
    Currently in the progress of building a carputer for my 1990 VW Golf. Have the computer and monitor sorted next on my list is the audio. Decided to use the following kit
    JL Audio JX360/4 Amp to feed
    Infinity Kappa 462.9cfp 4x6's in the rear
    Infinity Kappa 50.9cs 13cm components up front
    Was then going to use a JL Audio JX250/1 to feed the sub which ive not decided on yet.
    Basically wondering if I can use the preouts from the JX360 to feed the JX250 subwoofer amp ?
    Cheers
    Ian
    yes, that should work
    next project? subaru brz
    carpc undecided
      Hi,
      Thanks for the reply. Been a slight change of plans now have a Memphis EQ50 equalizer.
      Will it be as simple as using a 3.5mm to RCA cable to connect the onboard audio from the pc to the EQ and then connect the relevant channels from the eq to the amplifiers.
      The EQ specs state the Max level input is 50mV - 3 Vrms and Max level output is 3Vrms are these signal levels suitable to accept what I plan on doing ?
      Cheers
      Ian
