directed hd radio/ centrafuse? how ?
  • directed hd radio/ centrafuse? how ?
    I have an Directed HD radio that works on my desktop with Mitch's front end.
    I plugged it into my carputer project.
    It found Mitches Gadgets USB interface driver. It shows up in my control panel.
    In Centrafuse I have "HD Radio" selected in the settings.
    In Centrafuse, I always get "Radio Not Intialized, Retry?" I select "Yes" ... it says "Loading", but radio never works.
    What am I not doing right?
    Rick
    Make sure your port setting is 115200 in windows control panel. Just a thought SNO
      more to the mystery... I loaded Mitches Standalone control Interface to my carputer (worked on my desktop). It doesn't find the radio on the carputer either. This was painless on the desktop. I am totally confused. I know it is on Com 6 per control panel settings, but the interface software cant find it.
      SnotwistR... not sure what you mean by port setting 115200 in control panel. It says Port 5, hub 4 atm. where should I be looking?
        In windows/control panel/ports/com6(if that is the HD radio port)properties/port settings Click image for larger version
          OK , I found that... tried it... no change, but that brings up something to check. I'll drag it back to my desktop and see what the settings where when it worked on that.
            crap... embarrassing... the red wire fell off
            better now
            Rick
              As long as you found the problem, that's the main thing. SNO
                The tip about the baud rate was a good one.
                It was set by default to 9600, and worked at that rate, but was really slow to respond.
                115,200 makes for a much quicker response time.
                  baud rate in the control panel makes no difference
                  software sets it anyway
                  -Thanks
                  Mitch
                  www.rush2112.net
                  Sun, Come shine my way
                  Wind, Carry me home
                  The piece of me that died
                  Will return To live again
                    Mitch, thanks for interjecting.
                    I thought it was more responsive to commands after I set it higher, but it was a frustrating 6-beer night before I found the stupid power wire had fallen off.
                    Maybe it was just my ecstatic state of mind taking over after I found the problem and it all started working better.
                    Rick
                      beer, the cause of and solution to all life's problems....
                      -Thanks
                      Mitch
                      www.rush2112.net
                      Wind, Carry me home
                        "Homer Simpson"
                          My HDRadio was working, then I took everything apart to move it to my car. Once it was all back together. I can hear the Radio turn on. But I cant get centra to initialize the radio. Any suggestions on what could have happen? Where can I get a copy of the standalone software for testing the radio?.
                          Thanks!
                            Thanks!
                            https://skydrive.live.com/?cid=ed932...DABF9C9CB3!277
