In-dash amp only
  • In-dash amp only
    I'm starting on a project to hook up a Nexus 7, to, among other things, play music in my car. I want to hook up a small amp (in the stereo slot). I would prefer to have it as small as possible. I saw this thread: http://www.mp3car.com/car-audio/1402...n-in-dash.html where this was recommended: http://www.bybyte.com/amp.htm
    I thought that might be what I was looking for, but I have barely any experience in audio, especially car audio, and don't know what exactly I'm looking for. All I want is something that will allow me to plug in the 3.5mm headphone jack into the car, using my existing speakers. I have a 1998 Chevy K1500 pickup, with the standard stereo that looks like this (I'm pulling out the stereo for this):
    Click image for larger version
    Is this what I'm looking for? Any similar items that I'm looking for? How am I going to hook this up (i.e. are there any other cables I'm going to need)?
    Here is the one I use in my 96 S10 Blazer, very similar to the bybyte, but cheaper, unfortunately also from china so it takes 10 days to get it.
    I have a male to female 3.5 mm Y cable coming out of my DAC headphone plug and 2 regular male to male 3.5 cables to the 2 input plugs.
    http://www.ebay.com/itm/TDA7850-4-Ch...item5657d942c7
    TruckPC - gutted, being used for test setup
    BoatPC - All in 1 in cuddy, N7 using VNC on dash, RR
    BlazerPC - Nexus 7 with Timur's USBROM
      Thanks, so how do I hook it up? I couldn't find instructions on anything. Are the 4 screw-down ports on the sides where speaker cables go? They look like speaker connections. And the one on the front is power?
        In that ebay link if you scroll down enough there is a detailed diagram of the connectors.
          Could you repost the link? It just takes me to the ebay home page.
            Butt-splice this bad boy (verifyplz)
            http://www.amazon.com/Scosche-GM02B-...stereo+harness
            to this
            http://www.amazon.com/Pyle-PLMRMP3B-...+car+amp+3.5mm
            You could probably stuff this back there with out a problem. 6x3x1.5 inches. Granted it's no where near 200 watts per channel, but probably close to 20 per, putting you at the same level of the factory radio. As a plus the wires come directly out of it, which you can just crimp a plug or butt-splice it to the factory wiring. (as opposed to messing with a bunch of screw downs or solders) Looks like it has a 3.5mm input jack (or a set of stereo rcas) so you don't even need a y cable or adapter.
              to this
              That amp is 11" long. There's no way that would fit back there.
                I just checked the model number on three different websites and see nothing about a 11" dimension (just dumped the model number into a google search). Its all close to that 6x3x1.5. Maybe 11" is one of the dimensions of the shipping container?
                  Huh. Yeah I see that. Not sure where the 11" is from either. Thanks for the link! I hope that works.
                    Okay well I ordered those two items, and I'll let you know how it works.
                      to this
                      Thanks for the recommendation! I installed them and they work great! Here's my summary: http://n00bnerd.blogspot.com/2013/09/step-2-audio.html
                      I do note some feedback from the car's electrical system on the line, so do you have a recommendation for a good small filter?
                        for future searches... parts express has a line of good little t-amps. They are made by 'sure' check them out
                        New System in progress:
                        M10k
                        Phaze TD1500 ~> Seas g18rnx/p
                        Zapco Ref 500.1 ~ 12" tc-9
                        Transflective Xenarc
                        My Car Pc Install
                        My Boat Pc worklog
                          Thanks! I doubt I'll be needing another amp, but if anyone else wants to use a different one in a similar project, they'll have a resource.
