Car 5.1 Dsp Options Vs Pc 5.1 Dsp
  • Car 5.1 Dsp Options Vs Pc 5.1 Dsp
    There are only 2 useable mobile DSPís that are compatible with PCís the Audiobahn ADD51T & the Panasonic CY-AC300 EX or the older version the CY-AC300
    First I will tell you why you need a mobile DSP versus a PC based DSP like the Extigy
    Mobile DSPís are engineered for harsh noisy 12 volt environments there power supplies
    Are designed to block out the power surges and electrical noise from the alternator & ignition system
    The RCA outputs are a minimum of 3 volts peak to peak because of this they block out 98% of the radiated noise and prevent & reduce the severity of ground loop noise that wine you hear from the ignition system & alternator in an automobile
    PC based systems have a output of no more than 2 volts peak to peak & there power supplies have hardly any filtering they also use up computer resources & slow things down and often do not support Dolby Digital & DTS
    Here are some terms that are often used incorrectly
    Toslink is a connector used on some fiber optic cables but not all
    SP/DIF is 1 a transmission protocol like USB & IEEE1394
    2 it is also a transmission medium SP/DIF specís is a 50 ohm RCA cable also known as a digital audio cable
    AC3 is an audio CODEC transmission protocol
    Linear PCM also known as PCM is an Audio CODEC
    Dolby Digital Dolby prologic I/II & DTS 5.1 are all audio CODECíS
    Hereís how it works
    The computer gets the data form the DVD & sends it to a program like AC3 Filter witch extracts the codec you want say DTS then converts it to a AC3 stream and sends it to the sound card witch converts it to a SP/DIF data stream & sends it out the SP/DIF output or sends it out the fiber optic output as a SP/DIF data stream the SP/DIF signal sends the AC3 signal that is sending the DTS data to the processor where it is converted to separate analog signals kinda confusing I ainít it
    Hereís why other mobile DSPís wonít work
    The Audiobahn & Panasonic units are standalone units meaning they will work with any input that meets minimal requirements witch is a Toslink or Digital Audio cable sending a AC3 data stream they donít require other equipment to work properly they also have built in volume controls other units require a stereo RCA signal to control the volume and it is not easy to run 2 sound cards on 1 PC and have both being used by the same program at the same time
    The Pioneer DSP can be used if you use a pioneer head unit with it to control the volume
    What you need to do is to cut the pioneer fiber optic cable & polish the cut end & then put it in a Toslink connector so you can plug it into a PC or SP/DIF to Toslink converter if needed
    All other units Alpine Kenwood & so on canít easily be implemented with a PC because of the volume control problem
    Yeah! Real information on Mobile DSP! I wish my bank account had more zeros on the left of the decimal.
    TruckinMP3
    Read the FAQ!
      Nice Info. thanks
        Yeah, but doesn't everyone wish that?
          Thanks for the info port20
          So if you are will to use a headunit from the same manafacture for volume control are any other dsps useable?
          ie do they have Toslink or other easy to convert connectors?
          Proper Planning Prevents Poor Performance
            daiwilliamsuk here's your answer only with the pioneer
            other units require a stereo RCA signal to control the volume and the toslink or spdif it is not easy to run 2 sound cards on 1 PC and have both being used by the same program at the same time
            now if you can send analog and digital signals at the same time then you don't need a head unit
            it is very hard and sometimes not possable to use 2 sound cards with the same program but if you rewrite the app to do so it could work
              Thanks for the info. This was something I debated on how tyo implement.I was thinking about using the built-in Front L/R, Rear L/R and Sub outs going to a pair of amps (one 4-way for the Front & Rear and another to drive a mono subwoofer), and then call it a day.
              I've done looking for mobile DSPs and you're right: they are few and far between. The ones that do exist don't have TOSlink capability for optimal data transfer. And the two options you presented aren't cheap.
              How about the Wiki?
                What about Alpine's PXA-H510 and PXA-H700?
                  thanks again port20.. You've saved me a lot of time and money!
                    So would it be possible to use the stereo RCA output from a head unit playing any old cd to control volume? i.e. One audio stream from the computer (TOSLINK)to listen to and one from the head unit (RCA) for volume control.
                      so port, can i use the panasonic unit as my head unit? and control the volume and source from the panasonic unit. also, do you think there is any way i could wire my cd-rom directly to the panasonic rca input by using the analog outputs on the cd-rom that windows no longer uses?
                        I know Really old post but I intrested about this Audiobahn ADD51T. Most sites dont even carry it any more But i have a feeling there going to start to make alot more (http://www.audiobahn.com/Audiobahn06/pages/51606.html ) every were i look i get the same old picture and the same old discription and thats not really giving me the warm and fuzzys
                          Ditto. And the PXA-H701?
                            this thread is like 2 years old
                            New System in progress:
                            M10k
                            Phaze TD1500 ~> Seas g18rnx/p
                            Zapco Ref 500.1 ~ 12" tc-9
                            Transflective Xenarc
                            My Car Pc Install
                            My Boat Pc worklog
