Car computer sound output?
  • Car computer sound output?
    I plan on building a carputer in my BMW 318ti. However, i still have the stock radio in it. I've talked to my friend who installs audio/video equipment in cars and he said to still use my stock radio, but gain 2 auxilary inputs to the stock head unit, I would have to use a line out converter...
    http://www.mp3playerstore.com/stuff_...s/ISOLATOR.htm
    I want to run a cable that will convert the speaker output on the motherboard to rca type cables, and if this thing is what I can use, then I would just plug in those 2 rca cables into the "line out converter" and then it would pass through my stock head unit. I know this may not make much sense but I hope it does, and I hope there is a guru out there that can answer my question. Many thanks.
    that adapter converts the speaker output in to low rca outputs
    you don't need that
    you need a aux input adaptor for bmw this is a plug that will plug in to the cd changer port of the radio
    check here
    www.oemautosound.com
      The computer's headphone jack can easily be converted to RCAs. Get a $5 wire from radio shack to do this.
      Audio Rockford Fosgate: 900 Watt 4-channel amp, 501bd Mono amp
      Computer AMD 2400+ XP, 1 GB DDR RAM, Orbit Micro 250W DC-DC PSU
      Head units are for cheaters!
      sure some girls fake orgasms.....but it's guys like me who fake the whole relationship
        I dont Recomend the headphone to RCA converter with Cheep radio shack stuff, Might cause engine noise.
          ^what do you recommend then? To go from Mini Jack to High level speaker wire?
          Computer:
          COMPLETE SYSTEM OVERHAUL!!!!!!
          STAY TUNED IN THE UPCOMING WEEKS!
            Radioshack does have a mini to RCA shielded cable that is very nice and thick.
            Aopen i855GMEm-LFS with Dothan 1.8ghz
            512mb DDR333
            Windows XPpro SP2
              Works perfectly in my car. Sound could not be any better.
                Just wondering since I have a bose amp is there something that goes from RCA to High level? My amp doesn't have any RCA inputs. Sorry to threadjack.
                Computer:
