Loud noice when turning on CarPC
  • Loud noice when turning on CarPC
    Iīve just finished my CarPC projekt. Unfortunately (but not unexpected ), iīve got a problem. When iīm turning on my CarPC, the speakers makes a loud noice.
    I used the ignition lead to turn on en relay, which turn on both the CarPC and the amps...is this the problem?? What if i used a power-lead from the CarPC to turn on my ampīs? If i could, then iīm sure that CarPC get power before the amps...but would that solve my problem??
    //Andreas
    the noise...is it just a pop? or a constant noise?
    rebuilding carpc... kinda..
      Itīs just a "POP". When the CarPC is shutting down, thereīs no problem...
        Pop eliminators
        http://www.davidnavone.com/amp.html
          Or you could use a smiple switch..
          I have 2 switches. the first turns on the pc, the second my amps..
