Kenwood KDC-W6527 radio CD/MP3/WMA receiver & remote control
  • Kenwood KDC-W6527 radio CD/MP3/WMA receiver & remote control
    Just managed to get the first part of my MP3 Car system... a Kenwood KDC-W6527 radio CD/MP3/WMA receiver & remote control! For cost price of 150UKú
    Here are the specs:
    Compatible with MP3 and WMA format discs as well as conventional audio CDs
    Removable slide front panel with 3 step angle adjustment, switchable face-removed LED warning and security code
    Four tone 3D flourescent full-dot display with dimmer
    Rotary volume control. Red or green (switchable) button illumination
    Radio can be connected to factory-fitted remote controls and external dashboard displays on most cars (adaptor required)
    Compatible with current model Kenwood CD / MP3 changers
    Accepts RCA auxiliary inputs to connect iPod, walkman etc.
    Infra-red remote controller included
    CD-R / CD-RW compatible
    Display of CD text information from head unit or compatible CD changer.
    Display scrolls if necessary
    Disc Name Preset allows names to be assigned to discs in optional CD changer. When disc is selected the name will appear on the radio's display
    Disc Name Preset Play allows you to select by name any disc in optional CD changer. (Optional hand-held remote control is required)
    RDS (radio data system) & EON (extended other networks) tuner
    DAB tuner can be added as an option for Digital Audio Broadcasting reception
    Full coverage of LW / MW / FM wavebands
    Display of radio text information
    4 x 50 Watts max power (MOSFET)
    System Q-EX sound control
    System E's light provides high-pass filter and 5 step low-pass filter for improved control of sub speaker
    BMS external amplifier control
    Internal amplifier disable option
    0-bit muting for silence between tracks
    Switchable dual-zone allows playing different sources to front and rear speakers simultaneously
    Two RCA preout (2.0 volt) for connecting external amplifier (rear non-fade switchable)
    Display auto-dims when vehicle's side lights turned on
    24 hour clock display
    Two way telephone mute
    Automatic turn off (after selectable delay of 20, 40 or 60 minutes)
    Complete with full fitting and operating guide <-- always useful
    For a picture, check out http://www.justkenwood.co.uk/stock01/kdcw6527.asp
    I'll put a review up of it once I get it...
    Chewiee
    I Suppose I can now change my progress in my sig
    VW Mk2 Golf GTI 16V:
    Kenwood KDC-W6527 HU
    Silver Travla C134, Slot Loading DVD/CDRW,
    256MB, VIA Epia MII 12000, Carnetix 60W, Xenarc VGA/Composite TS and a GPS Mouse
    not to rain on the parade, but how is this special to a carpc?
    "If it works this good why F with it?" -KMFDM "Intro"
    Strive for ethical wardriving: http://faq.wardrive.net/
    My CarCPUs: v1 - 2000 | v2 - 2004
    Mp3Car Meets: http://detrimental.org/eyecandy/MP3CarMeets
      fancy pancy...but not better than my Clarion...mine even says "proffesional receiver" so ha! j/k...very nice aux input player
      DICE Los Angeles
        To Do With MP3s?!!
        Its all about the 'Line-in', oh and it plays mp3s if I have to remove it for some reason
        Chewiee
