Factory Stereo
  • Factory Stereo
    I have a 2004 Freelander, and it has the stock audio system. It does not have auxillary connections, so how might I connect my carputer to the existing sytem?
    2004 Freelander HSE | Lilliput 7" VGA Touchscreen| Via M10000 | 256 MB | 120 GB | DVD player | TN-200 | Opus 150watt |Windows XP Pro | Media Car | Routis & Destinator
    Try an FM Modulator, it'll feed the audio through your FM radio when you tune your radio to the specified station. You can pick them up on-line for around $20 or so I think. That's what I'm going with until I can scrape up another $700-800 to redo my stereo (next year most likely).
      Try an AUX - in adapter from www.connects2.co.uk (they have worldwide stockists)
      This page lists the freelander as one it works with... http://www.stceurope.com/connects2aux.htm
      It's much better than the FM Modulator I was using before - it is actually Hi-Fi quality, as it connects to the CD-changer input and modifies it into the Aux in. Cost me 59 and although it took me a while to decide whether it was worth it I am glad I did
      Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
      Car PC Status: Complete - Undergoing Software Redevelopment
        Ill take a look at that because I live in New York City, so there is way too much FM interference to use a modulator. One problem, is this Connects2 unit for a 2004 Freelander? It gives me three options for head unit types, but I don't know which it is. Head unit type:
        Blaupunkt BP9262 Single CD
        VDO DC597/C42/C43
        Alpine XQD101043PUY
        I have the stock 80 watt stereo without a CD changer. Any ideas?
          I have no idea (although I used to live 100 yards from the freelander factory in the uk!!!) - best thing to do is get the correct removal tools to pull it out (if it's like many around at the moment it will be an iso removal tool) and have a look at the sticker on the side/back; alternatively, phone your dealer's service department and ask them to check using the VIN number
            I called the dealer who directed me to a garage who wanted $150 for parts and $125 per hour (2-3 hours). Bah!
              What??? The aux-in part from connects2 is 59 ($120) and took FIVE MINUTES to fit (pull the stereo out, plug it in the back)
              Phone the dealer, and ask the service dept what head unit you have got, they surely should be able to pull it off their system. If you have too much trouble I might be able to ask someone at Land Rover, I probably know a few ppl that work at the factory and they may know what 04 freelanders in US spec have
                http://www.logjamelectronics.com/auxinpconv.html
                  Archimense, it looks like those dont support a 2004 Land Rover Freelander. Also, if I get such a device would I be able to keep my existing factory CD player, and switch between carputer and factory stereo.
                    I use an FM Transmitter. Instead of having it wireless, It is wired. I bought it at Fry's electronics for $40 then $5.00 for the RCA to Headphone cable. It's the rClarion FM200. It works great, plus I don't need to replace batteries because it runs off my car battery (Not through the cig adapter)
                    Hope this helps,
                    Rafste
                    P.S. If you don't have a Fry's Electronic near you, I will be happy to buy it for you, and ship it to you. You can PM me and we can payment discuss options.
                    Post # 3000
                      By the way,
                      It was REALLY easy to install. All you do is get power from the head unit, connect the fm modulator to the antenna, and then just find a place to put the modulator. I will post pics of my how I did mine when I get a chance.
                      Peace,
                      Rafster
                      Post # 3000
                        How exactly do you use it? Do you tune to a station? Does it sounds as good as an Auxiliary Input Converter?
                          Yes you tune it to a station, and all the ones I've heard don't sound as good as AUX input. My brother has a Pioneer headunit we mod'd for aux in for $10. Look around before you drop >100 on something.
                          My Carputer! (More Car Pics at the end)
                          2 Kicker Comp 10"
                          Epia M-9000, 256 MB DDR, 120 Gig HD
                          Check it out?!
                            If you get something like this: http://www.logjamelectronics.com/bli...alpdmxv1d.html
                            you can keep your cd-changer and add aux inputs.
                            But I can't say which ones are compatible with your setup.
                            Logjam carries just about every brand of input convertor I have found though.
                              I have looked around quite a bit, I just have no idea what my car is housing now, so its hard to make real progress.
