Simple volume control
  • Simple volume control
    I am looking for a simple 2-channel volume control device. Ideally it would have rca inputs. Right now I am using a couple of RCA-headphone converters and controlling volume with a headphone volume control.
    I really would like something more elegant than that.
    Cheers!
    Is USB alright with you? No RCA, but still a cool and simple device.
    http://www.griffintechnology.com/products/powermate/
    ________________
    ______ILL.1______
      soundblaster
      well, i do know that if you are running a sound blaster live you can actually make a two button volume up, down, mute control for your machine. It was a hardware hack i saw on a mod site somewhere. Shouldnt be too hard to find. I believe that it also still works with audigy cards as well. It is just two buttons, one for up, one for down, both for mute.
      a description is at this site: http://pc-mod.com/articles/live/
      http://www.gotsanity.net
        I already can control the PC volume. What I would like is an in-line volume control to separately control the front and rear speakers.
        It could be as simple as two RCA channels with a knob. I just can't find it.
        Cheers!
          If you really can't find one, make one:
          http://sound.westhost.com/project01.htm
          But where can you find a shielded pot..
            Check this site and see if this is what you are looking for. It's item N-22v.
            http://www.davidnavone.com/linedrivers.html
              Ah! That should do it. Somehow I missed it and I have bought David Navone products before..
              Cheers,
                Hi. Darmie here. I know it's been a while, did you buy that item from david? I'm looking to do the same, how did it work for you or did you try something else..?
                Thanks.//
                Cheers,
                My first computer install 2001 SS camaro
                http://www.angibabi.com/carputer/index.html
                My latest project. Much better. 2003 Mazda Miata
                http://www.angibabi.com/miata/carputer/index.htm
