ariel to rca
  • ariel to rca
    i currently have an asus terminator case with a built in radio tuner
    it came with an ariel antenna that has an rca input, is it possible to connect my ariel to the pc with a sort of convertor?
    the ports are obviously different
    see pic, it will probs make more sense! lol
    http://server6.uploadit.org/files/Azh2004-help.JPG
    Looks like you are in for a trip to your local Radio Shack for a soldering iron
    I have never seen a Car "motorola" styla antenna to RCA adapter. BUT.....
    You could get an "Antenna Extension" cable (whatever length fits your needs), hack of the end you do not need, and the solder it to an RCA plug. Should do the trick.
    -Phil
    1995 Thunderbird
    Clarion 9375 HU, 2X CDC1255 12 Disc changer, 7500 DSP/EQ/Xover (w/fiber optic interconnects), 7501 TV Tuner/Aux
    Xtant 1001d 1 Ch, 4180c 4 ch
    7" Xenarc VGA touchscreen
    1GHz Via-Nehemiah, 250 GB HDD
    XMPCR w/TOSLink, SB Audigy NX
      yep...jam it in there !!!!
      DICE Los Angeles
