Post if you use a USB FM/TV tuner
  • Post if you use a USB FM/TV tuner
    Lets see what the brands most people on this board use.
    Trying to find a common denominator for generic all purpose software like radiator. Some people can use it, some cant. How do you use yours? From the software in the box? What brand? ANd if you got it to work with radiator, how? Maybe some other people can try your method before they give up.
    USB FM/TV: Pixelview PlayTV 2.0 USB Pro
    Chipset: VXIS 7012
    Radiator supported: No
    How its used: Vendor software
    Reception: Pretty Good
    New Lilliput EBY701 For Sale http://www.nusantech.com/index.asp?c...at=TOUCHSCREEN
    SiRF3 Bluetooth GPS http://www.nusantech.com/index.asp?cat=GPS
    USB FM/TV: Hauppauge WinTV/FM USB
    Chipset: BT848a (I Think)
    Radiator supported: Yes
    How its used: Radiator & Plugin
    Audi S8 supercar
    Modded Xbox 400GB HD
    Rear 7" screen & navplus
    Toyota Hiace Van
    Shuttle PIII 866 256Mb 10GB OPUS powered
    MediaCar & Mappoint 2004
    Custom fit 7" TFT VGA TSK
      Those people with BT848/BT878 cards are lucky. Which plugin craigyb? As far as I know, there is only one right?
        The standard supplied BT8x8 plugin supplied with radiator.
        Using the hacked driver of course.
        With the PCI card it worked straight away, with the USB card I had to install the factory USB drivers and then the hacked driver.
        Craig
        Audi S8 supercar
        Toyota Hiace Van
          Does anybody here write plugins? On the radiator site it said you need to know Delphi or something to write them.
          What kind of technical info of the usb radio do I need to give someone for that person to write a plugin for me?
            I cant get it to work!!
            OK.... Apparently I keep trying the same driver also but get the same effect (cant load Windrvr)....
            I have the (Hauppauge WINTV PVR USB-FM unit) MDL# 43211 REV E123
            It works fine with the software that comes on the disk. but radiator says it cant load the driver when I download and install the bt8x8 plugin.
            SO lets step back here... maybe your expecting me to have done something else and im assuming I didnt need to. So here are my steps (from a fresh system)...
            Steps---->
            1) place wintv cdrom in drive.
            2) plug in USB cord.
            3) direct NEWDEVICE FOUND BOX to the cdrom (drivers load)
            4) install application programs (tv & radio) from cdrom (setup program)
            5) install *RADIATOR* (do not start it up yet)
            6) install *bt8x8 plugin*
            7) Start Radiator program (select external driver & bt8x8)
            8) Apply........
            9) ****get unable to load windrvr
            10) **** can not start bt8x8
            11) radiator program locks up have to CNTL+ALT+DEL & stop radiator
            12) email you for HELP!!!!
            so did i miss anysteps...
            Chuck
            www.XionElectronics.com
            **MY NEW STORE** Come Visit
              Hauppauge WinTV/FM USB works great for me. No problems
              CAR:2001 Ford Crown Victoria
              PC: Acer EEE 900HA with Win7 with CF 2.0.
              Memory:1G
              Drives:160gig
              WI-FI:Cingular
              GPS:IG2k9
              Screen:Xenarc 700TSV
              The Florida Meets Thread
                well thank you for letting me know it does work... now just got to figure out what everyone else is doing right and im doing wrong
                chuck
                  for starters, i am not using radiator. Using latest progs from hauppauge.
                  Memory:1G
                  Drives:160gig
                  WI-FI:Cingular
                  GPS:IG2k9
