Via M mobo with FM Modulator Sound Quality
  • Via M mobo with FM Modulator Sound Quality
    I have the Via M 10000 mobo and my OEM radio does not have an AUX input adapter available. Does anyone know what kind of sound quality I can expect from the onboard soundcard through an inline FM modulator. I tried to for it but I could not find anything. The other option is to use a tape adapter and live with the wire on my dash. Also, I have heard that sometimes a line driver can improve the sound quality, do you think that would be necessary. Thanks in advance.
    Jason
    My obligatory progress meter.
    [|||||||||||||||||||-] = 95%
    Basic Install done and all bugs fixed.
    Need: GPS, OBD
    From my own experiences I don't think a tape adaptor does much above and beyond that of a FM modulator. A bunch of different companies make aux input adaptors for stock head units without them already. i.e. blitzsafe, PAC Audio
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
      I searched the internet very well for an aux input adapter for a 2000 mustang but nobody makes one.
      I guess the main difference between the tape adapter and the fm modulator is that most fm modulators want a line level signal from what I have found from looking around and I was wondering if the signal the on-board sound card put out was strong enough or if I was probably going to need line drivers. So I have 3 questions.
      1) Is anyone getting good sound through an FM modulator from a via mobo and if so what brand fm modulator?
      2) If an FM modulator is going to be necessary is there any good and cheap ones without eqs and such things that simply boost the signal?
      3) Is there an aux input adapter made for a 2000 ford mustang (with mach 460 system)? (I know pie, blitz and soundgate do not make one)
      Thanks in advance
      Jason
      Need: GPS, OBD
        I have been able to get decent sound quality from a fm modulator, but the problem is that you can never turn the radio up very loud and being I live in the city it's very hard to find a channel that doesnt bleed over from another radio station, also when you travel there is always a chance that you will pick up a station on the same freq you are using, which sounds very strange I had that problem a couple times. The one I actually used came with a CD changer and someone didnt want it anymore I found they worked about the best for me. I dont know about the last question.
        肚子笑痛了
        S60 Install
          Would this work?
          http://www.discountcarstereo.com/detail.aspx?ID=430
            FM Modulator
            I use a FM Modulator !!
            Setup :
            Morex Cubid
            Epia M10000
            512 Mb/DDR
            40 Gb/HD 2,5 "
            DVD Slim
            FM Modulator: http://www.cartft.com/shop/catalog
            Car radio : Pioneer DEH-P3600MP
            In the beginning I had a lot of problems whit noise.... !!
            Remember to :
            Connect all - (minus) to same spot. ( Modulator & Radio)
            Disable the mic. on the motherboard.
            Take care of all the cabels... Dont mix power and audio
            But my pc generates some noise, and from where and what I still don't know.
            It is possible to buy an AUX-IN solution for car radio, but wery expensive !!
            And maybe not the right solution.
            Lazyboy 62.
              Setup :
              Morex Cubid
              Epia M10000
              512 Mb/DDR
              40 Gb/HD 2,5 "
              DVD Slim
              Remember to :
              Lazyboy 62.
              Your radio has an IPBus connector. It cost me under $5 to make an aux-in
              adapter for mine.
              [H]4 Life
              I'm a lesbian too.
              I am for hire!
                If you have IP-Bus then:
                http://www.crutchfield.com/S-K0hrvWi...h=ip%2Dbus+aux
                  check out www.autotoys.com they have aux in adapters for all kindso of ford vehicles, and many other makes, I just got one for my chevy silverado. Here is a link to the page with ford adpaters http://www.autotoys.com/x/catalog/OE...e_1_c_181.html
                  EPIA MII-1200, 512 MB Ram, Seagate 7200 RPM 160GB hard drive, Orinoco Gold with 5.5 dB external antenna, Lilliput 7" TS, DVD-ROM, M2-ATX, Rikaline 6010 GPS, Running Frodo Player
                  My Truckputer
