Can this DAC be used?
  • Can this DAC be used?
    I was wondering if I could use this DAC to send a good clean signal to my Xtant 3-channel amp from my EPIA Via M10k motherboard? Thanks for any help! http://www.nakamichiusa.com/auto/musicbank/dac_41.htm
    ~Adam
    It seems this is like a "linear" converter, it takes the signal from one digital line to output on one analog line.. twice like that.
    On a DAC for the M10k you need a converter that takes one digital input that has the 5.1 signals for all the analog outputs.
    Maybe someone can confirm?
    Etienne
      Can someone please confirm?
        bump
          You said 3 channel amp. Is that fronts and subwoofer or what?
          That DAC seems overkill... I don't think you need 2 in and 2 out. What are you trying to accomplish?
            Yes its fronts and sub...., im not worried about overkill, if It will work thetn its what I will use, I can get one quite cheap, I am looking into sending then absolutely best sound signal from my PC to my amp, and I was told that the SPDIF on my Via M10k was the best way to do this, so I guess the question is, can I hook this DAC to my SPDIF output on my Via M10k Mobo and then hook this Nakamichi DAC to my amp? Thanks for te help!
            ~Adam
              If you are looking at the one on Ebay that ends in 30 min, look at the DAC-101. It is a better unit - IMHO. There is one with a "Buy It Now" of $80 plus shipping ($15). I would get it, but have a different priority right now.
              1993 Mazda RX7
              Dell Inspiron 8100 (laptop w/docking station)
                Is that a "yes" it will work answer?
                  I don't see any reason why it wouldn't work.
                  If it didn't for some crazy reason, you could easily flip it back around on Ebay.
                  1993 Mazda RX7
                    6 min left for you to decide on this one.
                    1993 Mazda RX7
                      If that wasn't you that bumped it to $67, don't go any higher, you could get the other one for a little bit more.
                      1993 Mazda RX7
                        So what is different about the Nakamichi DAC-101 than the Nakamichi DAC-41? Has anyone ever used one of these in there car for a carputer DAC ?
                          Older design, but very well proven to do a good job. I've only used the DAC-41 with the Musicbank stuff.
                          Hell, I'll explain it this way, the guy that just sold the DAC-41 just bought a DAC-101 .... that should simplify it for you .... :-)
                          1993 Mazda RX7
                            I cant find any information at all, or any pictures of it, besides the one on ebay, any help? I appreciate your time!
                            ~Adam
                              It's a older unit, very simple, but you don't need anything complicated. BTW - you do realize that you won't get 5.1 this way, only convert it to a 2ch analog signal? Also, how do you plan on controlling the volume level?
                              1993 Mazda RX7
