software graphic equaliser
  • software graphic equaliser
    Hi All,
    I have been researching hacked audigy 2 zs drivers to use on my audigy 2 card, after plenty of reading I found the solution was quite difficult and not guaranteed to work, major results from link below:
    ( http://www.driverheaven.net/showthre...threadid=45004 )
    All I wanted was an equaliser (stereo x2 under the CMSS tab was nice as well),
    Sooooo, the question is, does anyone know of a software equaliser? The one in winamp is limited and only works with winamp, i'm looking for something that can effect all apps that interact with the sound card.
    Any suggestions
    if you can't find time to do it right, when are you gonna find time to do it over.
    i googled software+equalizer and found this site
    PHP Code:
    http://www.anwida.com/graeq.asp
    looks good, but is only a demo...
    EPIA 800, 512MB, 120GB, XP pro, roadruner...
      Yeah tried that but it doesn't actually EQ sound as it is leaving the soundcard, you have to open the wav file using this softare then EQ from there, it also doesn't except MP3's, therefore no use to me or I doubt most people on this board
      cheers anway
        I found one, just dont remember the name right now..
        I'll check it and post it when i come home.
        Nobody liked my monkey :(
          Now here it is...
          RTEQ
          http://members.aon.at/grxpage/
          I noticed that it does basicly same that anwida software but has winamp
          plugin and standalone version for line in etc.
          But this could help http://www.ntonyx.com/vac.htm , Virtual Audio Cable.
          So you route audio through Virtual Audio Cable and Equalizer.. That might work.
