Subs for carputer!
  • Subs for carputer!
    Hey guys I'm looking for subs to use with my install. First let me tell you guys that I don't know much about the audio part of the install. I know the basics of car audio, not too much.
    That being said I looking for two 10's or 12's for my car. They don't need to be extremly lound but they do need to have good sound quality. I'm going to be keeping my stock speaker for now, I'm just looking for the subs and amps to go with them. I will not be using my head unit just the amps for all the speakers. I don't want to spend a lot of money on them, my budget is something around 350 for the subs and amps. Any suggestion are welcome.
    I was considering the Rockford Punch series 2 or the Adire Shivas. Let me know what you think of these. Also if you could recommend amps to go with the subs it would be great.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
    350 for 2 subs and an amp??? not much to work with there, man.
    You could get 10" Infinity Perfect Subs for around $100 a piece. Thats what I use in my car and they really punch hard. I am not sure what to tell you about an amp. Been a while since I looked at amps.
    Car: 2000 Audi A4 Avant 1.8t
    Carputer 2.0: removed. Back to stock.
      Sheesh I have a 10" Pioneer in my car and thats plenty, if you keep an eye on Circut City and Best Buy, sometimes they have open item boxes and subs together I saw a dual 12" sub box with 2 kicker subs for $100, which from what i've seen is great deal considering most subs are at least $50 to $60 a piece and thats buying a non name brand sub.
      肚子笑痛了
      S60 Install
        My budget is flexible, but I don't want to spend a lot of money of the subs and amps, so something a little higher than 350 would be ok.
        Installed
          He's right, you might consider bumping up your budget a bit. This amp is a mono amplifier and stable to 2 ohms which means you could wire 2 subs in parallel to it and push 420W (Max I think). Price on that amp is $189 and it's about as low in quality as I'd ever buy. However since it's a sub amp it doesn't need to be super clean and should work fine for the designed purpose. If you went with a pair of MTX 10" subs from the same site you'd come in under you $350 budget. Quality won't be the same as with higher end products, but will probably fit into your system quite nicely since you're keeping the factory speakers. Been a while since I listened to any of Rockford's stuff, but I didn't care for them then and have stayed away from them because of it (bare in mind it's a personal preference).
            I am running with two Rockford Fosgates (I paid 45 each from www.ubid.com) and a JBL mono amp which I got for 200 off ebay. I just finished building up my car and will be posting it tonight to tomorrow. Remember the enclosure is the key to good bass. Understand the different variations of enclosures and find the speakers that will work best with that enclosure.
            The best sub I have worked with (especially if space is an issue) is the Kicker Solo Baric. Extreme amount of Bass very little volume required for the box. Look around I have found this complete with enclosure for under 200.
              I'm not worried too much about the space being taken up in my trunk, so the size of the enclosure doesn't matter. I'm going to be building a custom enclosure, probably ported. That is why I'm looking for the subs first so then I can make the enclouse according their needs.
              Installed
                ebay...
                loads on there, find some u want then buy second hand! not really much that can be wrong with a speaker. it works or it dont!
                lol
                www.leoncupra.co.uk
                  Get you some some jl's you'll never turn back. You could even go with a one 12w6 with a nice 600watt rms amp and I'd guarantee you'd love the sound.
                  Georgia Area Meet Photos
                    you don't need 2 subs. one is plenty. just figure out what enclosure you want. I prefer sealed cause of the tighter bass (but my current setup is vented). I'm running a cheap ($10 after rebate) infinity 1030w right now with an old jbl 600.1 amp. this setup if fine for me. I was looking to keep the size/weight to minimum. I'm going to be swapping the jbl with an audiobahn 8001 very soon for matching amp (got 6004 in for 4 channel now).
                    Seriously, unless your screaming for outside attention, 1 10inch (or 12 if you really want) is fine for really good sound quality. Anything over 400watts would be good. no need to go over 800
                      What do guys think of these, Phoenix Gold Titanium, I've read a few review on them and they seem really good. Not bad for the price because they are discontinued subs.
                      Installed
                        Or what do you say about the Phoenix Gold subs in general. How good are they with sound quality?
                        Installed
                          go to ebay the prices are much better. I would suggest a kenwood or audiobahn amp they are not expensive like jls and they arent crap. As far as subs go I highly recommend 2 10's over 2 12's. 12's are overkill and will lower sql. and don't buy a box just build one it really isnt hard. go to home depot buy some mdf wood and maybe some fiberglass if you want and your set and dont go to best buy they have a bad selection of stuff and its all overpriced. You are also forgetting amp kit which can be expensive. they go from 30-100. This will greatly change the sql so dont cheap out on that stuff espcially the rca cable. Also dont forget the capacitor you may need one.
                            Old School PPI 12"s, got some on eBay right now (sorry shameless attempt to peddle my wares )
                            "I'm a dick!"
                            "I must seek knowledge and it's bastard son truth" - The State
                              I kept my eyes open for a while and got two MTX road thunders for $69 it was buy one get one free! So I also got the warrenty on one too. Just saving up for a decent amp now. I have a silly 260watt piece which is 2 channel at 2ohm so it doesn't really push them but I have to say it sounds a hell of alot better then stock.
                              CarComputer Status: New Car & Broken (Motherboard Fried)
                              Owen JH | My Linux Blog | The Tech Fellows
