Noise... ugh
  • Noise... ugh
    Ok, so I finally got the sound system installed and it works perfectly when I connect it to a cd player. Now if I hook up the Inverter and connect the computer it works fine, without the system connected to the computer. If I hook up the sound to the computer (Epia M10000) I get noise. I have tried ground loop isolators but that made no difference. I tried other things, I did multiple 's and I found out that if I grounded the case on the computer it might eliminate the noise. The problem is that I don't have a case on the computer. Does anyone have any suggestions?
    The Epia M10000 has a reputation for having USB data noise filter through on the audio output, there have been a couple of discussions on here about it, and most just say get an external USB sound card. There have been threads about the version of the sound drivers being a problem. Sorry I don't have more details than that. I havn't had the problem with my setup, but then again I don't turn the volume up that high and I have rubbish speakers.
    Epia M10000, 256Mb RAM, 60Gb HDD, DVD-RW, External 120Gb HDD, Travla C134 case, Liliput 7" Touchscreen, GPS, 802.11, Bluetooth, FM Tuner.
      I tried everything I could think/find on the web and finally I installed an inline noise filter on the positive and negative lines to the pc and no more alternator whine. Is that the noise your getting? I tried multiple grounds, single ground to negative battery terminal and single ground to the chassis. All produced the same whine. Once I put this filter on, all the alternator whine went away. http://www.radioshack.com/product.as...t%5Fid=270-051
      I bought two of them on eBay, (and ended up paying about half price)thinking I would need one on the amp and one on the pc. I installed one this weekend and all the whine is gone. I'm still having extra noise on the line in for the XMPCR, but I can live with that.
      Peter
      Stop Buying New Music CD's.
      Hit The RIAA where it lives.
      Indash Motorized 7", Epia Nehimiah, 512 MB, 80 GB, DVD, Wireless G, XP Pro, XM PCR, Kenwwod 5 Channel 1200 Watt Amp.
        Ya I was pretty annoyed that day, and I realized that no matter what settings/combinations of drivers I could not get the 6 channel output to work on the onboard sound on the M10000 so I just bought an Audigy NX USB sound card. It works like a charm and the noise is gone. I didn't try that one item from the Radioshack link though, the Radioshack people were clueless on what I was talking about. I've just been lazy to actually place everything in the car, other than that the thing is ready to go, the monitor has been "molded" and nearly finished.
          Peter
          Would I place one of these on the Inverter or the Amp?
            Ground the casing of your power supply.
            Garry
            Co-Developer of A.I.M.E.E
            www.aimee.cc
              Garry
              So just run a wire from the PSU case to my normal ground point?
                Garry
                i have a morex 80W car PSU
                l0gic supply
                throw a moon
                heuvos vin chevos
                  The Audigy 2 NX sound skipping is annoying the hell out of me (Do the latest drivers on the Soundblaster.com site fix this?). Is there any way to get the 6 channel output on the Epia to work with Frodoplayer? I followed the manual on the Epia but it didn't output anything on anything except for the middle audio input.
                    there is also a jumper on the motherboard for the 6-ch audio. check that
                      wheres that?
                        oops, thought there was one... I was mixed up with the SPDIF. Sorry, I guess it's just the settings in Windows.
