Sound card reccomendation for **music**
  • Sound card reccomendation for **music**
    I have searched pretty thoroughly and I just can not find any help. It seems like everyone is really concerned about setting up their car for 5.1 or 7.1 so they can listen to DVDs, but all I really care about is the music. I drive an MR2, so its not like I'll have passengers in the back that want to watch DVDs while I am driving
    My current set-up (off of a headunit) is a 4-channel amp powering my Kicker Resolution components, and a 1-channel amp powering my Image Dynamic woofers. I am looking at developing a CarPC around a sound card that meets my needs. I don't care about 5.1. I don't care about 7.1. I don't care about how perfect DVDs could sound with surround sound. I don't care about cards that come bundled with pretty software that lets me mix my own music, or record my own music. I DO care about sound quality.
    Right now, I am looking at some cards made by AudioTrak and Terratec, but I was hoping that some of you more experienced folk could shed some light on this for me. What is a good sound card for pure sound quality, that will let me adjust the levels of each speaker and will let me control the level of my subs? I have read here that some of the Audigy cards will only put a signal to the LFE channel if there is no bass coming from the other speakers. That is the sort of thing I am trying to avoid. Thanks for any help.
    Thomas Barrett
    Carputer Progress Meter
    {[|-------------------]} 5%
    Research and planning.
    Car: 1991 Toyota MR2 Hardtop
    Stereo: Planet Audio TT4300 & TT1250D, Kicker Resolution RS6 (front) & RS5 (rear), Image Dynamics IDQ12V.2 D4 (2x), Sony CDX-M610
    I bought a terratec off ebay. it sounds really nice & clear but it is a little bit lower than the one on the motherboard. I bought some cheap line drivers and will try those out. Terratec six pack 5.1. 45.00 delivered.
    Stop Buying New Music CD's.
    Hit The RIAA where it lives.
    Indash Motorized 7", Epia Nehimiah, 512 MB, 80 GB, DVD, Wireless G, XP Pro, XM PCR, Kenwwod 5 Channel 1200 Watt Amp.
      Lower?
        yea, the output voltage on the m10000 is either 3.3 volt or 5.0 while the voltage from the terratec is 1.1 volt. I think thats why the volume doesn't get as loud now as it used to. I bought some cheap line drivers from ebay. If these punch up the volume then I will buy a good 6 channel line driver for the system and be done with it. I bought the terratec card because it has an optical input and I needed that to upgrade the sound from the XMPCR.
          i use an extigy, atm my system isnt operational so theres a diskman plugged into my amps and in comparison it sounds awful
          Signature: [==||========] 20% complete
            I use a SB Audigy 2 NX. 102dB s/n ratio is significantly better than most aftermarket head units.
            I then connect the SB to an Audiocontrol three.1 line driver / equaliser. If you are serious about car audio, get one of these. You can control your subwoofer from this in-dash unit via knobs vs. messing around with software settings on your carputer to change your sub volume. The line driver portion of the unit is ideal for a carputer setup also.
              http://www.newegg.com/app/viewproduc...121-101&DEPA=1
              comes in 5.1 as well but i don't know what else may have been changed. trust me. this is as good as it gets..
                Agree, I recently got an M audio card and am very pleased with quality. Although not a game card at all but for audio I would say better then an Audigy.
                  I also use the Audigy NX...its sick.....right from my lappy to the Audigy..and I get great stereo sound...
                  [SIZE=1]02 C Black/Black, SMGII, Intros Aero Polished 19s, K&N, HAM, XM 2, Sirius, V1, GT2, Garmin 2610, Carputer with Xenarc
                    I aree too, being able to adjsut individual speaker or subwoofer levels via the stereo system is a much better idea than via the computer. less distracting, easier adjustment.
                    with that in mind, and as the goal, then it really doesnt matter what card you get. your signal will be in stereo, so your requirements will be a single output of left and right signals. even the headphone out on a laptop could work wonderfully well. for music.
                      I am actually considering getting one of the 30-band 1/3octave equalizers. I forfeit the convenience of having the dials in my dash, but I find that I don't fiddle with the outputs on my current head unit much, if at all. Once the imaging and sound are correct, the only thing I *ever* change is the level of the woofers. I don't mind using software for that, cause its only a few times a week that I change music genres
                      In regards to the Revolution 7.1...its outputs are front, center/LFE, rear, and back surround. With my current plan, I'd actually use all of those outputs. My question here is how do I differentiate the center and sub outputs? My center-channel speaker will be self-amplified, and my sub amp(s) will need a seperate signal. Do you let the equalizers and/or crossovers (external and internal) do the work? I guess I am just having a hard time visualizing exactly how everything would go together. And also...how does the M-Audio Revolution 7.1 compare to the Terratec Aureon 7.1?
                      Thanks for the help so far
                        Lots of high quality sound cards used by professionals in mastering:
                        http://www.egosys.net/
                        They have both 2-channel and multi-channel sound cards. I'm looking at the Audiotrak sound card myself as a decent alternative to the Audigy cards (sounds crappy), M-Audio(better), and Mad Dog Entertainment(never tried).
                        I use an older EGO-SYS 24/96 waveterminal sound card, and it sounds wonderful (especially compared to an Audigy sound card which i also have installed purely for game playing).
                        I'm planning to have a surround install in my car, and the only variable left is a software based surround sound engine (with bass management). Think of it as the software equivalent a surround sound receiver. The software should at least process most of the movie surround modes (Dolby Digital EX, DTS ES, DTS MUSIC) plus Dolby Prologic II (Movie AND MUSIC), and couple of proprietary surround modes thrown in ( Circle Surround, SRS, Meridians Trifield, etc.) Wishful thinking at this point, unfortunately, but I'm sure someone will come up with it eventually. That is the beaty of a CARPUTER because component upgrades would be just soundcards, and processor upgrades would be just software....
                        Chris
                          i just bought a sound blaster 4.1 for only 5 bucks at a local electronics store. after the 10 dollar mail in rebate. woot woot
