Connecting CarPC to the Speakers
  • Connecting CarPC to the Speakers
    I am trying to work out the best way to connect my imminent CarPC to my stereo system in the car.
    My options:
    1) Connect Aux in line - My stereo has no Aux In line and would mean that I have to buy a box that would utilise the CD Changer port, therefore loss of CD Changer. (I might need it for those days the CarPC decides not to play)
    2) Changer head unit - Nah, like the one I've got.
    3) FM transmitter - Heard bad reports about sound quality and interference problems.
    4) Buy a small AMP and tap into the speaker wires - All 6 channels, plus mount the amp, plus supply it power, sounds like a lot of work!
    or
    my idea -
    The CD changer is a factory fitted VW one. It it secured in a panel within the boot, (where the PC will also sit). The wires are visible. My plan is to cut the two audio wires, and place female Phono connectors on the 'Head unit' end and male Phono connectors on the 'CD Changer' end. This way I can plug a line out from the PC into these. Then the Head Unit thinks the CD is playing, but whilst the disc is spinning the audio feed is actually coming from the PC. Then when the inevitable happens and the CarPC refuses to play, I just reconnect the audio lines to the CD Changer and I have got the CD Changer whilst the PC is undergoing surgery. Also if i sell the car then it can also be connected back.
    I have checked and the feed from my CD Changer is Analogue not Digital Coaxial.
    This idea occured to me and seems far to simple. Please someone offer an idea of why it won't work !
    Or if you think it will let me know.
    Thanks,
    Matt
    Hi Matt,
    That's a good idea. I might be doing the same. I'm still in the planning stage and this is something that I stumbled on. Have you done it yet? Did it work?
      Originally posted by shal
      Hi Matt,
      Yes it works. Although I currently have buzzing noise issues I think I will resolve them. I have tried other sources such as portable MD player and it works fine. You do need to check the your CD changer pumps out an analogue signal rather than a digital one. The audio only gets cut when the cd changes the disc.
      If it doesn't work, it is easily reversed.
        Matthew do you have a 2004 jetta or simiular? If so can you please tell me how to tap into the wires maybe a diagram so I can do the same IF we have the same vehical.
