sub box
  • sub box
    aight, I'm a total noob to hardware stuff.. so keep that in mind
    I'm making my sub box this weekend and I've seen sub boxes with a plexi glass window in them, and I think that would be kewl to do.
    my main questions are
    1. Is plexi glass actually what I want to use ? plastic ? I dunno.. make some suggestions
    2. Would it totally destroy the sound and purpose of the box ? Like, would I be able to seal it well enough to where it would still sound alright ?
    3. How would I get the plexiglass(or other material) flush to the box ?
    sorry if these are newbish.. I have no idea about any of this stuff.
    I consider that our present sufferings are not worth comparing with the glory that will be revealed in us.
    www.neoterikos.com
    I suspect if it is heavy duty plexiglass (1/4 inch) and well sealed it should be ok.
      Since you're a newb, I'd start with a simple sealed enclosure that's matched to your subs. Do yourself a favor and buy a speaker design book. The boxes that you're seeing are called 'band pass' and there's actually a fair bit of mathematics that goes into setting one up and tuning it properly...they sound like crap if not properly constructed or properly matched to the subs and the rest of the system. Before you touch one of those, you want to take the next step in complexity up from the sealed enclosure and design a ported enclosure.
        alright.
        I feel quite competent in math and I'm willing to learn about the different boxes.. you still reccomend a simple sealed enclosure for the first time ?
        www.neoterikos.com
          also..
          a sealed enclosure + window = bandpass ?
          'cause that's really all I'm going for
          www.neoterikos.com
            Originally posted by pimpJ
            also..
            it is usually a ported enclosure + window = bandpass
            And I will also warn you...if you don't get this right...it will sound really bad! I bought a bandpass box from Best Buy with 2 10" speakers in it and it sounds alright for my purposes. However, if I take the plexiglass off the front of the box, you can barely hear anything at all. What this tells me is that fairly a lot of planning went into designing that box for its use. From every angle, the size of the box, the subs used, the wood used, the plexiglass, and the seals, etc....etc... I certainly wouldn't want to build my own bandpass box - but if you go for it...keep us updated and Good Luck!
            2001 Isuzu Rodeo CarPC
              alright, we'll see how things go. I'll look around a bit more and see if I can find anybody I know who could help if I did decide to go the bandpass route.. we'll see
              thanx
              www.neoterikos.com
                A window has nothing to do with whether a sub box is a ported/sealed/bandpass enclosure...
                Just replaces a wood panel so you can see your expensive subs...
                And I too recommend a sealed enclosure for your first box...
                It will give you nice tight/crisp bass response.
                A ported box will "boom" a lot harder tho... if thats what you want...
                CarPuter: Dell P3-500 Laptop; D-Link WiFi; Deluo GPS; D-Link Radio; iMac DVD w/ ide2usb
                Audio: Audigy 2 NX; Kicker KX700.5 amp; 20w center amp; Kicker L7 10" Sub
                Display: Lilliput 7" TouchScreen
                CarPuter Install
                  ok kewl, sealed box sounds good. I was wondering why a window without a port would make a difference ?
                  I may just do a sealed box with 5 walls wood and 1 plexi
                  thanx
                  www.neoterikos.com
                    A window in a normal sealed box does nothing but let you see the baskets of your woofers. The boxes that typically have windows have them in the front and are bandpass boxes. IIRC (I haven't messed with box construction in years) the subs are wired out of phase with each other and what you actually listen to is the backwave of each playing through the vents.
                    A sealed enclosure is typically the smallest, easiest to construct, and gives tight bass at the sacrifice of some efficiency.
                    A ported enclosure will tend to boom and be more efficient *around the tuning frequency*. Tuning is critical as is selecting your crossover frequency. You'll get weird artifacts like 'chuffing' if it's not setup properly. Also, the box would be larger than a sealed box for the same subs.
                    Start with the basics, man, and learn how to build a good solid enclosure. Then play with a ported enclosure, then move on and try the band-pass.
                      I agree , start simple with a sealed box, you'll be happy you did, save the Plexi for another day. Also to get good sound I found that the position of the sub in the car/truck can make a HUGE difference in the sound. I like to have a box that I can move around and try out before I attach it to the car in anyway.
                      I had an Infinity perfect 10 in my explorer and if I point it to the front nothing, point it towards the back BOOM! So experiment with it.
                      As far as those subs and amp, haven't heard anything about those brands good or bad, but the seem like a good combo.
                      Matt
                        aight thanx.
                        he's talking about this
                        please check it out
                        www.neoterikos.com
