Volume Knob help
  • Volume Knob help
    Im a bit confused what this guy is doing here. Can i put the knob in the middle of the Y Audio Cable? Know what i mean. I bought this ,but its kinda hard to fit that into the dash and look good. So id rather use the knob. Any help?
    I GIVE FREE HUGS!
    Buy Sell or Trade
    If my pm box is full, please feel free to call me any time. 440-328-3382
    Thank you
    Forex
    Rate Mp3car @ FXroot.com
    Yes. Just put some resistance between the incoming (sound card) and outgoing (amp/headunit) and ground the two shields together. Thats it.
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    7" Lilliput TS w/DigitalWW in-dash mount
    80GB External HD
    I am Zero Bitrate....
      that knob you have is perfect for what you are trying to do, there are stand alone options that are already assembled though, I know alpine makes one, as does many others. you should be able to find an alpine one on ebay for around 20 bucks, with an awsome looking knob & rca in & out already attached & ready to go, not to mention they use a ground shield scheme in there assy that will help avoid noise introduced into your system,
        I have searched for alpines knobs but couldnt come up with anything. So what i need to do now is this. I have this , how do i put the volume knob in the middle? I have a spare cable but still to worried about cutting it. But guess i can to test it if someone knows how to do it.
        Thanks guys,
        J
        I GIVE FREE HUGS!
        Buy Sell or Trade
        Thank you
        Forex
          k ima just cut the extra one i have and use that so i could just but it and connect it to the one in my truck so i dont have to cut that one. Ill post pic of what the cable looks like if i cant figure out how to do it.
          I GIVE FREE HUGS!
          Buy Sell or Trade
          Thank you
          Forex
            Well no need for pic i guess. It has there wires one red, yellow and black. Im assuming that the black and ground and the red and yellow are the left and rights. Ima hook it up and see if it works. brb
            I GIVE FREE HUGS!
            Buy Sell or Trade
            Thank you
            Forex
              R is always for 'red' and always for 'Right'
              So;
              Black - GND
              Red - RIGHT
              Yellow - LEFT
              http://www.digital-car.co.uk
                Well i did it but its all screwy. I did exaclty how it showed the left channles being down. Also i did the exact same thing on the other three posts for the right. The sound is all distorted?
                Edit: Although i did the right on the bottom three and the left on the top three.
                Know what i mean? would that do anything? Where he shows he did the left i did my rights there.
                I GIVE FREE HUGS!
                Buy Sell or Trade
                Thank you
                Forex
                  OH i have one ground on the top and one on the bottom would that mess it up?
                  and I dont get sound till i turn it all the way to end(all the way to the right)
                  I GIVE FREE HUGS!
                  Buy Sell or Trade
                  Thank you
                  Forex
                    ok i fixed it. I have to conned both of the grounds. But it I still have to turn it to the end to get sound. The knob is pretty much pointless? I mean there is not enough turning for me to adjust sound. Its just on and off?
                    Edit: ok i get better sound from my desktop rather than my laptop. Would ya suggest gettin a different volume knobby thingy(potentiometer)?
                    I GIVE FREE HUGS!
                    Buy Sell or Trade
                    Thank you
                    Forex
                      Doh im a big dummy it works perfect in my truck with the amp. Awesome. Now i just need to find a matching volume knob. Sorry for all my ramblings its a sunday evening. IM SO HAPPY it works.
                      Thanks for the help guys
                      Found one, my factory stereos
                      I GIVE FREE HUGS!
                      Buy Sell or Trade
                      Thank you
                      Forex
                        So;
                        Black - GND
                        Red - RIGHT
                        Yellow - LEFT
                        Just for clarification purposes... Red is not ALWAYS for Right. In most unbalanced audio (rca cables and such) red is right, but in most balanced audio cables the red/black pair is Left and the other pair (often green/white) is right. This goes back to the time when audio was mono and there was only one channel red/black. When stereo came around it was popularized that Left would be the "mono" channel and thus left was the red/black pair and the new pair would be right.
                        Just sharing
                        As for the Pot to add resistance to lessen the volume, make sure you're using an audio taper pot instead of a linear taper. If you use a linear taper pot, there will be a large area of the turning that seems to do nothing and a small area that makes it go from full to silent. Audio is logarithmic not linear.
                        Just sharing again.
                        2006 Chevy Colorado: VIA M10000 EDEN, 1 GB RAM, 80 GB 2.5" Seagate HDD, USB Slim Slot DVD/RW, Holux GPS, MobileVU 10.4" LCD (touch not working yet), VOOMPC Case (blue), 70W DC-DC supply.
                          Just sharing
                          Just sharing again.
                          this guy is 100% correct, I just assumed you were starting with an audio pot, but if you have a linear taper pot you will experience the symptoms described...
