noise in epia integrated sound card
  • noise in epia integrated sound card
    Hallo i use the ac97 sound card integrated on epia m10000, when i star the pc i can listen noise....the noise when i move mouse, the noise when i click with mouse, the noise when i open cd-rom, the noise when read a cd-rom.....
    The solution for kill noise??
    pci sound card (creative) or usb soun card?
    help
    My Home page
    Cartuper V2
    Epia M1000
    512Mb ram
    Hdd 40 Gb 2,5'
    Dvd recorder DL Panasonic
    Lilli 619 7' with TS
    SoundBalster Mp3+ USB
    Holux Gpslim236 usb + external antenna
    M1 Atx
    Remote control with girder
    Your post isn't very clear: does this happen during testing (with the PC outside the car?) or only while it's in the car? Because if it's only while the PC's in the car, check your grounding. Search to find out what to do.
    If it happens during testing, make sure you have a real case and it's hooked up right to make sure it isn't grounding. If it still happens, try putting a ferrite bead on the speaker wire as close to the amp (or head unit) as possible. You can buy them at radio shack for less than a dollar.
    Old plans out the window because of an accident .
    Have: M1-ATX, EPIA M10000, 256MB, 60GB 2.5", slim slot load DVD
    Need: Time, HU integration, ideas for Lilli
      Make sure that you computer has a good ground. Use at least the same guage wire as your power and ground to the closest to the computer. That should help, I know it did for me
      Remember AllAdvantage From 7 years ago? IT IS BACK! Now under a new name Agloco
      GET PAID TO SURF THE INTERNET
        If this is electonic noise, like noise as the hard disk is seeking then there isn't a lot you can do about it apart from getting a USB sound card. Try the grounding option first though.
          the problem are inside the car and outside the car, i have the only one point of ground for all components(pc,radio,amp)
          My Home page
          Cartuper V2
          Epia M1000
          512Mb ram
          Hdd 40 Gb 2,5'
          M1 Atx
            are you saying that it is grounded?
            I GIVE FREE HUGS!
            Buy Sell or Trade
            If my pm box is full, please feel free to call me any time. 440-328-3382
            Thank you
            Forex
            Rate Mp3car @ FXroot.com
              yes, i try with car battery and with external acdc adapter.....and in both case are noise in soun card
              My Home page
              Cartuper V2
              Epia M1000
              512Mb ram
              Hdd 40 Gb 2,5'
              M1 Atx
                How are you going to power your computer? Where is it located and where are the grounds points?
                I GIVE FREE HUGS!
                Buy Sell or Trade
                Thank you
                Forex
                  i power computer with two battery,(for survivor tank).
                  the computer are located under seat and the ground are two meter in the baggage car
                  My Home page
                  Cartuper V2
                  Epia M1000
                  512Mb ram
                  Hdd 40 Gb 2,5'
                  M1 Atx
                    You may also want to check that the sound wires are far away from the power wires.
                      Well i have found that in my computer if i ground it to the frame that i get the same noise. Everytime i do something on the computer i would get a noise. So i changed a few things around and i grounded it to the cig lighter.
                      Yeah that helped me out too.
                      I GIVE FREE HUGS!
                      Buy Sell or Trade
                      Thank you
                      Forex
                        the soun wire,the preamp wire and the power wire are near all in a tube
                        My Home page
                        Cartuper V2
                        Epia M1000
                        512Mb ram
                        Hdd 40 Gb 2,5'
                        M1 Atx
                          help
                          thats funny because Im getting the same thing only difference is that its not in my car yet, still testing it in my house......DO you get any sound thats hearable - I just get all noise - nothing
                          looking into PCI or USB card
                          [M10K][TinyXP][Roadrunner Frontend][OEM Enclosure]
                          [iGmon]
                          Download MP3 MixTapes
                            that is your problem then IMO
                            one of the first rules of car audio is to NEVER run your power and signal wires in the same area. They should be as far as possible from each other. Pull the power and run it on the other side of the car (or as far away as possible from the signal cables).
                            Also, make SURE that your grounds are 100%. This means scraping away any paint or other material that would prevent pure 100% metal to metal contact.
                            Good luck!
                            Jan Bennett
                              the ac97 chipset has this problem for a variety of reasons. you hear a humming when you move your mouse a lot or when stuff on the screen changes quickly right and it's a constant humming right?
                              i never actually saw a solution being posted, but one solution suggested was that because of the pravalence of the ac97 chipset, sometimes windows will install legacy drivers that aren't entirely compatible but works but has issues with interference with your graphic card chipset driver. what i did was to reinstall XP and install drivers that came with the motherboard. that worked for me, but i'm not sure that was the issue.
                              another stopget solution is to get a PCI or USB sound card. since the ac97 chipset is hardly any good, if you are any type of audiophile, it might be a good idea to invest in one of those.
