Pioneer P-Bus
  • Pioneer P-Bus
    I have a Pioneer DEH-P717 and have the P-Bus connection in the back for a CD Changer. I did a search on here and found out a few things about getting converters for it etc. So I did a web search and found a P-Bus to RCA adapter. Well I actually found alot. So I kept searching and found a good priced one (they range from US$15.95 to US$49+).
    Here's a link to the site: Pioneer P-Bus to RCA Audio Adapter and it's only $15.95!
    I bought it in the hopes that I can put the P-Bus to use as an aux input and not have to buy a new headunit with an aux input for when I put a pc in my car
    And before someone says "Why didn't you just buy one in your own country?". The reason for this is because the only place I found them was from Pioneer New Zealand and they are NZ$99! And I also bought this too from the above site.
    I like stuff :D
    It's IP-Bus.
    I built mine for $5 and 20 minutes.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
      Carputer: 2.8Ghz P4, 512 RAM, 120gb HDD, WIFI, TV tuner, CDRW/DVDROM, Slot load DVD in front.
      Screen: Lilliput 7" touchscreen (Custom made Carbon Fiber Screen Enclosure)
      S2000 Carputer
        like mr. frodo said, build one.
        info on building one:
        http://www.gutterslide.com/ip-bus_hack/
        肚子笑痛了
        S60 Install
          Originally posted by frodobaggins
          It's IP-Bus.
          $5?? Wow, I built mine out of an old CD-Rom audio cable for free. What did you spend 5 bucks on?
          Tidder
          Try RevFE
            probably the beer he was drinking while doing it
            肚子笑痛了
            S60 Install
              oooooo I will have a go at building one today
              Thanks for the info guys
              I like stuff :D
                The 12 ft rca cables. I already had the cdrom audio connectors.
                [H]4 Life
                I'm a lesbian too.
                I am for hire!
                  Btw, gutterslides is a little more difficult than the one I built, let me see if I can
                  dig up the pics.
                  [H]4 Life
                  I'm a lesbian too.
                  I am for hire!
                    Yes, it works, thanks dude...
                    www.dashpc.nl --- forum.renault19.nl
                      dig up the pics.
                      yeah I couldnt find the other pics on the site since attachments are not working.
                      肚子笑痛了
                      S60 Install
                        the $50 unit on ebay allows for pass through, meaning you can still have another unit plugged in... so you could have AUX and a cd changer .. or in my case... AUX and XM...
                        the cheaper unit is the same as what these guys are making...
                        EPIA SP13000, 512 DDR400, Seagate 300GB, Belkin PCI 802.11g w/external antenna, Holux GM-210 GPS, XM Direct w/ serial, Dlink FM, Opus 120 p\s, Rockford P4004 amp, Xenarc 7" VGA touchscreen custom mounted in double din spot -- see pics and write up here!!
