How to hook up 1/8" Stereo Output Jacks to RCAs for Amps?
  • How to hook up 1/8" Stereo Output Jacks to RCAs for Amps?
    This is really aggravating...
    Both my motherboard and PCI soundcard have 1/8" STEREO outputs, so essentially I need to make a 1/8" splitter to dual RCA jacks for each of the 3 ports.
    The thing is, the 1/8" splitter to dual RCA jack from Radio Shack (see pic below) is too thick, and thus I can only plug one into my card at a time!
    So what are you guys using? Are you using a 1/8" extension to one of these above splitters? An extension like one of the ones below (right angle or corded)
    It's 6 feet long though!
    Should do the trick
    - Vorex Out
      Originally posted by Vorex
      you can find shorter lengths of the same cable.. go check at bestbuy or at radioshack.... so you dont have to worry about all 6 feet of wire cluttering up your install
        or use they seem to have reasonable pricing.
          i just soldered my own 1/8" stereo plug where it connects to the sound card. nice and neat!
          99.9% complete.
            Spike, buddy, this is at least the second old thread you've resurrected today to grace us with your insight... you really should consider looking at the date stamp on these posts before replying... chances are nobody's still waiting from 2004 for a good price on 1/8" phone to RCA adapter cables...
            But don't take it from me! here's a quote from a real, live newbie:
            Originally posted by Viscouse
            I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
              aww come on man...he's just trying to get his post count up!
              my $0.02 worth on the post however is to stay away from using the onboard audio (unless we're taling about SPDIF) won't get very good sound outof that 1/8" jack....and it most definately won't have enough signal voltage to make a ****....(.5v if I remember right...which is NOTHING)
              Jan Bennett
