On-board Audio VS. Sound Card
  • On-board Audio VS. Sound Card
    I'm not really thrilled with the current sound quality of my system.
    I've got onboard audio from
    VIA VT1612A 2-channel audio Codec
    http://www.pcchips.com.tw/PCCWeb/Pro...=Specification
    But It's really not doing it for me.
    What i'm wondering is... As far as MP3's go, if i purchase a new soundcard (pci/usb2) how much improvement might i actually see?
    Is it worth it to upgrade from on-board audio?
    mobo $130 ; 150wOpus-$200 ; 256mb pc2700 -$10 ; 120gb HDD 7200-$70 ; Lilliput TS 7"-$265 ; USB LAN-Free AR ; Rikaline 6010 GPS-$34 ; ShuttleXpress-$37
    Total = $746....Carputer = Priceless
    They all sound the same. The only thing you might benefit from with an external card is, its ability to expand to four channels, an EQ, sound shaping algorithms, etc etc Your basic MP3 will still sound exactly the same
    Current Setup
    Nexus 7 Tablet
    Built in head unit
    Brutus 1500Watt Amp
    Two Boston 12" subs
    2006 Infiniti M45 Sport ;) My 4 door Camaro... lol
      "Not really doing it" in what way?
      System status: in progress
        there is a big differance in sound quality between my onboard sound and my extigy sound card, "they all sound the same" could not be further from the truth
        Signature: [==||========] 20% complete
          When my audigy I died for no reason I was left to use my onboard sound, I think its the same chip as yours. And the sound was noticebly worse, even to untrained ears.
          PowerVoice v1 | NaviVoice Source
          GammaControl v2.4
          SKINbedder v3
          1995 Lexus SC300
            You have a PcChips board? The board layouts on those are designed to minimise costs, and not to minimise noise, so the onboard sound is usually quite crappy. Go for a good USB soundcard.
              Do some research before going to a USB soundcard. They are overhyped and don't work that well in a carpc enviroment (limited inputs, 100% volume upon resume, the list goes on....).
              GammaControl v2.4
              SKINbedder v3
              1995 Lexus SC300
                And please do some of your own.
                While those are valid points, not everyone has these problems,
                and the sound quality is usually quite good.
                [H]4 Life
                I'm a lesbian too.
                I am for hire!
                  well then on that note...
                  Is Anyone currently using a usb sound card without any problems?
                  What kind?
                    Soundblaster MP3+ USB, no problems at all, it has RCA inputs and outputs. And it's only $39
                    肚子笑痛了
                    S60 Install
                      I have a SoundBlaster MP3+ too and not one problem!
                      Remember AllAdvantage From 7 years ago? IT IS BACK! Now under a new name Agloco
                      GET PAID TO SURF THE INTERNET
                        I use onboard sound from an emachines board and am happy with it.
                        TruckinMP3
                        Read the FAQ!
                          extigy, no problems
                            Audigy1 noticeably better than my onboard sound.
                            Epia SP1300\512 ddr\40g 3.5" hd\cartft-touchscreen\GPS-destinator \M1-ATX\Audigy1\Linksys-wirelessB\anafekkingbigamptojblspkrs.
                              Me also, and I have it running through the headunit amp, the quality outstrips CD's
