Lost 12V power after rewire. Help!
  • Lost 12V power after rewire. Help!
    I've seem to have lost my 12V power going to my headunit sometime during a rewiring project.
    Background:
    2000 Ford Mustang, aftermarket Kenwood head unit installed by Best Buy.
    What I did:
    I wanted to tap the 12V wire to power a mobile monitor. However, sometime during the process I lost power from the factory harness. Now I can't power either the monitor or the head unit, together or separately. I've checked voltages with a multimeter.
    What I've done since:
    I've checked all the fuses in the passenger compartment. I looked up my fuse box diagram and swapped out any fuses that were associated with the radio.
    Any ideas on what happened?
    2006 Rav4 + iPod, still CarPCless
    Fuses in the engine compartment?
    Fox Mulder
    2004 Toyota MR2
    Modified Intel Xeon E5450 3Ghz Quad Core 2GB RAM 160GB SSD M4ATX Xenarc 700TSV TS Toslink Audio BU353 DiNovo Mini Car2PC ODBII Bluetooth HF 16x2 Character LCD
      Check all the butt connectors and see if a wire pulled out? I know how some of those "pro's" install, and it makes me sick. If no fuses are blown, there is a good chance something simply pulled out. Look in the areas that the installer would have messed with.
      2005 Ford Focus ST
        Checked the butt connectors myself. In fact, I redid the butt connectors on the 12V and the ground because theirs was sloppy. At least theirs worked.
          I'll take a quick peek, but I'm not sure if there are any fuses there that are connected to the radio.
            Are you missing constant 12v or switched 12v? If it's constant, you probably blew the dome light fuse.
            2005 Subaru Legacy GT
            Status: 40% - starting install
            AMD Sempron 3100, Biostar K8NHA PRO mobo, 512 meg DDR, WD 200 gig SATA, Opus 150, Xenarc
            JBL GTi 6.5 fr, JBL 5.25 rr, (3) JBL 75x2 & 1 1200x1 amps, PA MOFO 12 sub
              I went to Wal-Mart and picked up a fuse checker. Turns out one of my fuses in the engine compartment was bad, I just couldn't see it at first. Thanks for all the help.
