Anyone know A LOT about amps?
  • Anyone know A LOT about amps?
    I turned over my mtx thunder 250D and took off the back cover, it looks like some of the capacitators may have blown, there is all that crap that are in them, scattered throughout the amp.
    I was wondering, could I just try and replace them, or should I try and send it into a pro, and if so, what is a good place, that don't charge the **** out of you.
    I just bought this off someone, I haven't hooked it up yet, but I am pretty sure it will not work, I bought it for really cheap though.
    2009 Altima 2.5S CVT Dark Slate
    by some new caps,,, it is easy to change since they are huge on amps. i change caps all the time in PC motherboard and the one i mess with are like 20 smaller than the one you deal with but i still manage to replace them fairly easily. here's a link for the best capacitor i know off that can work up to 125C and have a lice cycle but have been tested to be guaranteed 50,000 hours at 85C
    http://www.secc.co.jp/retri_e/os_rlt_index_e.html
    Direct connect#173*300734*8
    SEXTEL Done.l
      Well How do I know which ones I need?
        I highly suggest that you talk to the person that sold you this, and make sure that they realize it was sold to you like this. And if you can't fix it without paying big bucks, you want your money back.
        If that already happened to the amp, maybe something is faulty in it that you can't fix. If you replace the caps, the same thing may happen again. That's my suggestion at least.
          Anybody know about capictators?
            I would take the thing back, IMO MTX makes crap my friend is a big MTX guy but I have fixed his subs time and time again as well as his amps
            Nate
            I know what yer thinkin...did he fire six shots or only five...
              i've got a mtx thunder 404, and its been working for a couple of years just fine. however thats not on the high end mtx stuff, maybe the more expensive stuff is more prone to problems
              CarPC install is starting to come along again...
                That could be, his is
                Nate
                  I'm not gonna take the amp back or any of that, I posted here to find out if it is fixable or not.
                    In my experience amp caps this big go because of another problem on the board. A lot of times it is because the output ohm load was too low and the amp finals blow.(thatís the final stage of amp transistors) look around on the board to see if the is any tar looking material close to the transistors. if so there more to repair that just the caps.
                    They are always fixable. The question is will it cost as much as a new one with a warranty.
                    Really the only way to know is have someone look it over.
                    800 225 5689 - MTX Customer Service & Amplifier Service Center
                    Randell Kelly
                      Okay, I found out that my fuse on my power line was blown, so now the amp works fine, thanks a lot for the help.
                        reciepy for fire?
                          Umm yeah. Blown fuse and a bunch of blown up caps? That doesn't sound like it should be working at all. It takes a pretty good short to kill a cap, way more than any of the other components in the amp. But hey, if it works, it works. Keep an extinguisher nearby.
                            The amp was never hooked up to my system, When i first got the amp, i took off the backplate and looked inside, its what i do. anyway, i noticed some of the caps didn't look too good, so i was assuming they were blown.
                            Then i hooked the amp up, and figured it didn't work, but just to make sure, i bought a mulitmeter and tested the voltages and all that. Found out my inline fuse was blown, and now the amp seems to be working fine.
                            Once again, thx for all the help here.
