Audio Quality on Epia M10000 (verdict not so good)
  • Audio Quality on Epia M10000 (verdict not so good)
    Seems that folks are all over the board when it comes to the quality of the on-board M10000 audio. I will share my first-hand experience for those who have yet to make the on-board audio decision.
    Now that I have my system fully integrated and functional, I must say that I'm not too happy with the audio quality I'm getting from the M10000. I'm using the onboard 5.1 (ignoring the center channel) to my amp, and the bass that the sub channel is putting out is pretty weak. I'm talking about the frequencies below 100hz or so. I have a single 12 in my trunk. Compared to the M10000, the stock 'business radio' unit (which was already of marginal quality) I had in before was putting out a richer signal. The M10000 just sounds a bit flat.
    Have any of you been able to achieve decent audio quality? Maybe with an external usb sound card? I'm talking about a quality approaching that of a top-of-the-line pioneer or comparable system.
    Thanks for any info!
    R
    If you'd used teh SEARCH tool, you'd know the answer.
    If you can make use of the SPDIF-out, that's the best way to go for quality. The trick is finding compatible audio components. They're out there, though.
    How about the Wiki?
      Assuming that you read my first sentence, yes, I have searched and I usually try to before making an *** of myself
      My amp doesn't take SPDIF, so I'm bound to analog. I don't want to add another digital-analog component into my car either.
      Anyway, I was able to improve the signal by making changes to my software: I now divide the volume range into 3 parts, which I call soft, hard main, and hard F/R:
      hard F/R range: ( 0db -> -10db) software is at full volume, sub is at full volume, front and rears are adjusted as one.
      hard main range: ( -10db -> -35db) using system main volume control here (software still at full volume, but all 4.1 speakers are adjusted as one).
      soft range: (-35db -> -70db) at this point I'm using the software APIs (audio, video, dvd) to make volume adjustements, since below -35db the hardware volume controls don't work properly.
      Also, I have a bass boost dial hooked up into my amp, so that I can make quick adjustments based on the music I listen to.
      So... with this I'm relatively happy with the bass output, but in the next few months I will give an external usb audigy a shot, too. Theoretically this should clean up the signal.
      R
        anyone have the external Audigy? results?
          Yes. It's better.
          2004 4runner
            I have been very impressed with the Xitel Pro Hifi link (http://www.xitel.com/product_phfl.htm) for digital and 2-ch analog out.
            This may work for you for multi-channel output:
            http://www.m-audio.com/products/en_u...ater-main.html
              Let's look at your first sentence, shall we?
              Says nothing about searching or reading manuals. Only that you want to impart information to other users. Nice idea. You're to be commended for that, although the information you presented is hardly new.
              But then you bust out with a query:
              And at this, I responded appropriately.
              If you'd searched, you'd kknow what people have done to achieve top-shelf audio quality.
              Here's a thread to point you int he right direction, assuming you want to go the route of using SPDIF output to a digital decoder:
              http://www.mp3car.com/vbulletin/show...ighlight=SPDIF
              How about the Wiki?
                Hey man just pick up a nice EQ take the line out on the sound card use the y splitter 1/8" headphone jack to RCA's then connect it in to the EQ. Then run the RCA's to their corresponding amps. Clarion makes a pretty nice EQ and its not that expensive Clarion EQS-744 http://www.ikesound.com/product-product_id/1923
                It takes the voltage output from the computer from about 0.5volts to 7volts which will give you a better cleaner signal that should make it sound much better. If you dont like that clarion look for something comparable.
                  Thanks Bulldog, I think that this will be a good solution.
                  I don't want to go w/ SPDIF out because I want to control the volume with the PC, and not another external device. This way I can keep using my steering wheel controls for volume.
                  My next step will be to try the Audigy 2 NX to see if I can eliminate some noise and get a bit more power into the sub channel. According to the specs, this sound card should output about 2 volts or so. If this is not enough for my amp, I will try adding the EQS744 between the sound card and sub. Just waiting on the Carnetix 1280 I just ordered so that I can get the 5 Volts to the Audigy.
                    Fatman -
                    How did the AUdigy work out for you? I'm in the middle of extensive searches and came to find that you are doing what I plan to do. Did you need to use the Clarion EQS744 to really make it work...or did the Audigy do the trick?
                    Toyota Tacoma Install
                    BMW 325Ci Install - Old
                    ZOTAC H55-ITX, Intel i3 & 320 Series SSD
                    7" Lilliput 669GL, M4-ATX, SB X-Fi, XMPCR
                    Win 7, RR, Garmin, DashCmd
                    Morel Elate 9 3way & IDQ10 ported (active 4-way),
                    JL Audio HD Amps, Audison BitOne.1
                      Hey thats my thread.... funny... read post #2
                      I was going to suggest using the SPDIF aswell. I am very pleased with it.
                      And the 5.1 sounds awesome
                        BimmaDrew, I will know by the end of the week. I'm just waiting on UPS to deliver the Carnetix 1280, which they say will be here by Wednesday.
                          your problem lies in that the viltage out of the computer is super low (something like .5v)
                          you really need at least 2v to have a decent signal and signal strength - this is achievable by using an eq like was mentioned before, or a line driver to bump voltage.
                          as for external card....I'm using the SB PCMCIA Audigy for a laptop (optical in/out) and have nothing but good things to say about the sound quality...no noise either.
                          Jan Bennett
                            so the PCMCIA audigy did work fine then even though it had a higher min requirement than the VIA boards are? want to go with that but hadn't because of the high requirements they had on it, if it did work on your MII12000 then I think i'll get one and give it a try, mines a little slower, MII10000, but both are well below the requirement specs.
                            2005 Dodge Magnum RT, Samsung Galaxy Tab install
                              I played it for over an hour (burning in speakers since they are new - need about 9 more hours on them) without a single problem...not even a glimpse of a problem
                              keep in mind though that I'm not running a bunch of other programs or visualizations while burning in speakers....I'm more concerned with tuning to prevent anything from going wrong on the speaker/amp side of things right now...lol
                              I gues I should start a thread about it to let others know that I haven't had a problem.....since I had like 10 different people ask me about it....=]
                              Jan Bennett
