RCA dynamic voltage range...?
  • RCA dynamic voltage range...?
    i am having difficulty choosing a set of amps for my vehicle. Lacking a multi meeter i have no idea how much voltge is output from a computer's soundcard on each channel. Does anyone know the range? does teh sound card effect it?
    Gigabyte nForce2pro (rev. 2) onboard sound
    amps in question take a range of 150mv to 4v
    or 120mv to 5v
    depending on set i get
    Any idea guys? Im tryin to prevent clipping and burining out things if i can.
    Thx alot
    from my testing - the ONBOARD sound puts out only .5v
    you will want to boost that voltage to an acceptable level. I used an Arc Audio PEQ-7 which is an eq, it boosted my voltage to 9v. Doing so will give you a much cleaner sound. You also won't have to worry with trying to find an amp that matches your output voltage of your sound card.
    In general, i think that you are looking at this with too technical of a
    just pick an amp that you like, and get something like an eq or other that will boost your voltage level to an acceptable level...
    Jan Bennett
