No aux on pioneer?
  • No aux on pioneer?
    Well i have a pioneer deck, deh-p740mp, and i bought the cable that turns the cd changer port into an aux port, but i cannot find a way to switch to aux.
    In the instructions it says to hit func until aux becomes available and turn it on? I tried but there is no aux button whatsoever.
    Any ideas?
    there is an option when you access the menu when the headunit is off. You have to push one of the buttons...access the menu, then scroll to aux and turn it on.
    Via epia M10000
    12.1" VGA touchscreen
    XP Pro
    OPus 150W
    120 GIG Maxtor
    512 DDR
    Geforce 5500 Videocard
    Audigy NX USB sound card
    Wireless Keyboard & mouse
    Panasonic slim line -slot load
    w/ usb adapter
    IRMAN
      yeah, turn the unit off, then press and hold the function or source button untill the time comes up flashing, then use the arrow keys to get to aux on or off
      肚子笑痛了
      S60 Install
        And if it still doesnt work then you need to . Oh nevermind you should have done that before posting.
          Chill out man we already fixed the problem.
          肚子笑痛了
          S60 Install
            But still man...
            Tidder
            Try RevFE
              Ok, Yesterday I had the same problem and after reading the pioneer manual I discovered that you have to power-off the radio and then press the function key until a message appear on the dispolay.
              Now my problem is another-one I hear the music just from the rear speakers for the radio and CD everything works fine, I tried everything but no music from all the speakers... I changed all the settings but nothing happened, I changed the RCA cable, I tried other sources .... nothing
              any idea ?
              thanks
              EPIA MII 12000, KINGSTON 512MB, Sapphire GPS, 60 Gb 2.5" HD, slim CD, Terratec Cinergy 600, lilliput 7" TS, XP SP2, Frodoplayer, PhoneControl, MapMonkey
                The pioneer manual says nothing about shutting the unit down first, so before you start running your mouth before reading up on things yourself you should consider a thought process.
                  maskone
                  Each mode has its own audio properties saved(cross overs, fade, balance, ect). Sounds like some one jacked you tuner settings. If you can't figure it out disconnect your battery to reset the radio.
                  '99 F-350 Crew 7.3L~'02 F-350 Crew 7.3L~ '04 Dakota SLT+ 4.7L
                  MII12000opus120~MII12000opus120~MII10000opus150
                  NA~Senao dual 7.4 ant~Orinoco Gold
                  Pioneer~Pioneer~PG Octane-R R5.1MT
                  Xenarc, Rikaline6010, Garmin OEM16 HVS, CoPilot10
                    after you enable the aux, now you need the RCA to IP-Bus converter...about $30
                    Molded Screen:
                    [++++++----] 60%
                    DVD & Rest of audio:
                    [++++++----] 60%
                    2004 Accord Coupe, Satin Silver K24 5 Speed powa!
                    7" Lilliput Screen, non touch with lots of Bondo
                    NTB DVD player or put XBOX in car
                    My 04 Accord Picture Thread
                      If you read his first post he states that he bought it.
                      Visit my website at:
                      http://www.hostilejava.com
                      http://hostilejava.com/gerbil5.jpg
                        completely read over it....I never saw the letters, I, P, B, U, or S....LOL
                        sorry about that
                        Molded Screen:
                        [++++++----] 60%
                        [++++++----] 60%
