Phoenix Gold R5.1MT
  • Phoenix Gold R5.1MT
    Volume control?
    Phoenix Gold R5.1MT
    amplifer has TOSLINK (aka SPDIF ? ) input and on board Dolby 5.1 Processing on board. Looks like it would make a great amp to run directly off SPIDF out of via / shuttle using this cable
    Searched the forums and it seems that there is no way to controll volume via touch screen with computer hardware. Amp does have IR sensor and a little remote but is there and way to have volume knob???
    None that I know of. I just use the remote. If you need a knob you have to use one of the processors that output to amps. They come with HU face plate looking things with knobs. More expensive, more space(with amps), more power. If you big into audio equipment, it is the way to go. I was only looking to replace my HU function so the r5.1mt worked for me.
    '99 F-350 Crew 7.3L~'02 F-350 Crew 7.3L~ '04 Dakota SLT+ 4.7L
    MII12000opus120~MII12000opus120~MII10000opus150
    NA~Senao dual 7.4 ant~Orinoco Gold
    Pioneer~Pioneer~PG Octane-R R5.1MT
    Xenarc, Rikaline6010, Garmin OEM16 HVS, CoPilot10
      Hi at all,
      excuse me, but when you change the master volume via touch screen change the input signal on the amplifier and will change the volume or not?
      At home I've a kit creative digital connect to the SPDIF of Asus Motherboard, when I change the volume on the pc it change in the creative.
      Byez
      ITALIANI: DISPONIBILI MODULI OEM GPS:
      http://www.mp3car.com/vbulletin/show...214#post639214
        Right now I just use the IR remote. I hope to soon get a pac-audio decide which will turn my factory streak wheel controls into a universal remote and then use them to control the volume.
          Originally posted by slimmegane
          ...when you change the master volume via touch screen change the input signal on the amplifier and will change the volume or not? ...
          It doesn’t control the volume via the optical input, for sure. I'm not sure about the coax input. I haven't been able to make my coax inputs work at all.
            Volume control?
            Phoenix Gold R5.1MT
            can anyone still find this amp on market?
            kao
            CarPC Ver 4 completed. Aopen i45GMT-HD, C2D mobile 2GHz. Photofast 64GB SSD. Novatel EU-850D
              nope - it's been gone for a while apparently!
              might try email PG directly though!
              Jan Bennett
                did that. discontinued
