Alpine HU w/ Aux in. Just clarify one thing for me please.
  • Alpine HU w/ Aux in. Just clarify one thing for me please.
    If I use the AI NEt Aux cable and plug my Alpine into the onboard sound card, then I would simply use Source and switch my Alpine to Aux and all the mP3s on the carputer would play through the alpine, correct? Even though Iv'e got amps running off the alpine too? Thank you. I've searched but didn't find anything that helped.
    you are correct!
    Jan Bennett
      Thank you very much.
        "If I use the AI NEt Aux cable and plug my Alpine into the onboard sound card, then I would simply use Source and switch my Alpine to Aux and all the mP3s on the carputer would play through the alpine"
        what does he mean by Source???
        i want my audio setup like this.
          If it's like my JVC HU there is a button, usually with a name like SOURCE that switches between FM,AM CD,Tape, AUX, Line in,etc. In my case its AUX that the computer is on.
            Yep, alpine is the same. However, my Alpine can not control volume on aux.
            It's the cake having/eating thing.
              WTF?!? That must suck. I guess you have to use the computer to do that. I prefer the volume on the HU myself.
                Did you have "defeat" On or Off for Aux? Maybe that help, but I am not sure.
                Source here is audio source (FM, AM, CD, Aux/CD-Changer, ...) On most/all newer Alpine, you have to buy and aux adapter to plug in the changer port for aux audio in. Also, you have to change the setting under setup to have aux enable.
                Y2K Accord Dell GX150
                EmoRebellion is a SCAMMER
                  oh damn, i hope my alpine controls volume.
                  i got CDA 9831.
                  someone straighten this up.....
                  auxin from alpine to amp or line-in on mobo? or both?
                  i have phoenix gold amp and VIA M10000
                  thanks
                    yeah you'll be bable to control volume.
                      Hey more mods, I'm sure there's a way you can set up your HU to control volume on aux input. I came across the same thing on mine and solved it.
                      As soon as I arrive home I'll tell you how
                      See you!
                          dont we all love the aux option on after market headunits :-D i know i love mine
                          - split it into 3 inputs pc dvd and another one for quick mp3 hookup or something
                            am i really that bad with electronics? whats going on? im so damn confused.
