Best way to connect 8 gauge wire to 12-16 gauge wire?
  • Best way to connect 8 gauge wire to 12-16 gauge wire?
    Finally have all my car audio and power parts in (amp, sub, amp install kit). Back seats and paneling have been removed from my car. Have a remote audio video switcher, as well as an inverter and other goodies. Anyway, just a few quick questions:
    I will have 4 gauge power cable from battery to to trunk distro block, at which point it will branch off into 3x8 gauge cables to feed an inverter and and amplifiers. These lead back to another ground distro block.
    I need some smaller 12 volt power lines to power a Sirius tuner, the amplified video switchbox, and maybe a rear view camera. Whats' the best way to get 12-16 gauge cable from the above setup? It's kinda unwieldy to wire crimp the 8 gauge and 16 cables together. I'm thinking I could solder one end of the 12 gauge cable to one end of the 8 gauge cable and then put that entire assembly into the distro block connector.
    Suggestions?
    2006 Rav4 + iPod, still CarPCless
    8 gauge is a little big but.....
    you might be able to find something along these lines:
    Jan Bennett
      or this:
      Jan Bennett
        Originally posted by Red GTi VR6
        or this:
        You're just showing off now...j/k - you're setup is tight.
          Cool, where do I get something like that?
            ghetto style - twist and electric tape
            whatever you want to do man it will work just make sure its a nice tight seal especialy if its coming from ur battery.... why dont u wire the smaller stuff like camera to a fuse under ur dash or something its easier and u can choose if u want it to turn on when u turn the key or alwayz be on... have fun
              lol - thanks
              you can get stuff like that at any home depot, lowes, electrical supply store, etc
              Jan Bennett
                this is about the most unprofessional way you could do it. it's not secure, and it's far from pretty, not to mention unsafe...
                but the fuse thing makes sense
                lol
                Jan Bennett
                  lol
                  it may not be the best method but it works, it works especially well if you solder the wires then tape them up. i find connections where whe wires are only twisted and taped to hold up to abuse much better than any of the crimp style connectors commonly used
                  Signature: [==||========] 20% complete
                    Anyone used these things for splicing in?
                    http://cpc.farnell.com/jsp/endecaSea...CBA-560B&N=401
                    Could be ok for low power things
                    And red, i have to second that - you are such a show-off But i am being jealous - wish i had the time, money and skills to make something that nice.
                      you must not be crimping them right then, or something, because a correctly crimped joint will outlast a twist and tape any day.
                      And yes, a solder joint with tape over it would be a nice option, but not very user friendly when it comes to taking stuff out etc..
                      that's why we went with the strips in my car, to get the amp rack out we can just disconnect at that strip, disconnect the power, ground and remote leads at the other strip and dist. block, and unscrew the rcas....pull the entire amp rach out and not have to worry about running it all back through the tubes....because that was a PITA!
                      just giving him options that are user friendly
                      Jan Bennett
                        how is it showing it off??
                        I guess I should have spent the time to find a picture of those online somewhere else hu?
                        btw - those t-taps are ok, just not for 8 gauge wire.....but you won't find any t-taps near my car (unless they are there from the factory) (btw - THAT comment MIGHT be considered showing off a little....lol)
                        Jan Bennett
                          Hey Red, in the above picture, are your blue cables power or speaker wires? What exactly is that white plastic thing called? Does that go on to feed your smaller power wires on the left?
                            those are speaker. We did that for two reasons actually, for the reason mentioned above, but also so that if I needed to put a speaker out of phase we could do so easily back there....then again, the alpine processor will switch phase as well...
                            it's basically a terminal strip
                            the other one that I listed (second pic) is actually a terminal strip. Basically, we brought power, ground and ignition to it, jumped them over to 3-4 other terminals and can split them from there, can also easily disconnect everything and trouble shoot, and test at this point as well
                            Jan Bennett
                              Semi-ghetto 8-to-12ga:
                              Crimp ring terminals onto the 8ga and the 12ga's, then use a small nut/bolt/washer to bolt all the rings together securely, and wrap the whole thing in tape or heatshrink.
                              95 Chevy G20 Vroom Boom Room
                              ...with a whole bunch of nifty ****... go check it out: VanDomain Page
