have you thought about "TUBE" MB and Sound?
  • have you thought about "TUBE" MB and Sound?
    This thing is one of the kind
    take a look
    http://www.digit-life.com/articles2/aopentube/
    Wow, the concept of that is cool, wonder if it really makes a difference in sound. I have a Carvin Guitar Tube amp and it definately sounds a lot different than the digital amps....
    I guess the next step will be the "punch card" motherboard.... I can hardly wait for that one
      that is just the coolest thing i've seen in a long time!!!
      New System in progress:
      M10k
      Phaze TD1500 ~> Seas g18rnx/p
      Zapco Ref 500.1 ~ 12" tc-9
      Transflective Xenarc
      My Car Pc Install
      My Boat Pc worklog
        If you read the article it said that it smoothed out the sound but was bound by the cheap codec. More of a marketing ploy than an actual audiophile motherboard
          can you imagine having http://www.techwarelabs.com/reviews/...ges/tubeon.jpg
          this in custom case in your trunk.... i wonder what is the Preout Volt off RCAs
          Plus you can install different TUBE and chage sound way u want.
            yeah I wanted one untill I found out it was AC'97, they released that board quite a while ago.
            肚子笑痛了
            S60 Install
              Tubes can only make a difference to the sound when they're used on the output stage, i.e if they are right before the signal hits the speakers. When its part of a system like that, its just a gimmick, they run the tube on the input signal (which does nothing except add distortion) and then feed it into a solid state amp.
              If you want a tube amp, get a real one : http://www.trutechnology.com/products/copper/c72_at.htm
              BTW, just to clear up any confusion, DONT compare a tube guitar amp to a normal tube amp, they are COMPLETELY different things. The Guitar amp is designed to add even order (warm) harmonic distortion to the guitar signal. You dont want that in an amp thats REPRODUCING music and not CREATING it, because its adding something to the signal that isnt there in the first place
